Install wifi card
Where is the installation slot for the wifi card in a compaq presario r4000 notebook?
Undo the four screws near the screen on the underside, pull the panel above the keyboard out. Remove the four screws holding the keyboard down, there should be a slot for the wifi card along with two leads which you plug into the card (do this first so as not to put pressure on the slot)
Posted on Dec 13, 2008
    Sergeant:
    Champion:
  • 417 Answers
Please Rate The Live Chat Session but the 1st of may or you could be charge non rating fee
Posted on Jul 31, 2008
Nhbg
Posted on Jul 06, 2008
I just need to know if thisHp compaq presario sr2020nx pc desktop is wifi compatible
Yes it is compatible although you will need to fit your own Wifi card. There are two types of card, PCI and USB. To fit a PCI card you will need to open up the PC and install the card into a spare PCI slot. To fit a USB card you simply plug it into any spare external USB socket.
Oct 19, 2010 | HP Compaq Presario SR2020NX PC Desktop
I'm not hearing sound from my laptop type presario compaq R4000
You require sound card drivers
Look in your user manual for what sound card you have and then look for drivers for that part of sound card makers website.
Jun 22, 2010 | HP Compaq Presario R4000 Notebook
Installing XP SP2 on Compaq Presario R4000, after
Run a HDD Test
Restart Computer -> Immediately keep tapping F10 Key which is on 1st row of Keyboard
Go to diagnostics with your arrow keys
Go to Primary HDD Test -> Press Enter ->
See the Test result
If Fail then Contact HP for Replacement of HDD or Service
Jun 01, 2010 | HP Compaq Presario R4000 Notebook
I install a screen screen for compaq r4000 bout it not showing the display bright
you may need to set your backlight settings. it could be done under power settings in your operating system or you may do it manually by pressing fn + up arrow key (or down arrow key).
also make sure you have the latest driver for your computer!
Mar 31, 2010 | HP Compaq Presario R4000 Notebook
Problem with compaq presario r4000 constant beeping no keyboard
Need to know the number of beeps. They're called beep codes. This page lists some of the Compaq beep codes and what they mean.
http://www.bioscentral.com/beepcodes/compaqbeep.htm
Nov 06, 2009 | HP Compaq Presario R4000 Notebook
SATA 2.5 connectors different than current Presario R4000 laptop
It seems that your notebook does not have sata connection to Hard drive. Your harddrive is IDE connection. Sorry but you can't use SATA on this laptop.
Oct 22, 2009 | HP Compaq Presario R4000 Notebook
Compaq presario r4000 randomly hybernates
Go into the control panel and go into power management or power options and change the standby settings. Its probably set to go on standby mode after 30 minutes without use or something like that
Sep 18, 2009 | HP Compaq Presario R4000 Notebook
I have a compaq presario r4000 will not boot up correctly
When you start it up, go to the BIOS option and select "peripheral" settings. I don't know which column its under but you want to turn the network adapter off. If that makes your Operating System come up working (And you may have to come up in SAFE mode the first time), then you can always go back and reset the BIOS to recognize the network adapter, or install a different one.
Jul 05, 2009 | HP Compaq Presario R4000 Notebook
No sound
Do you have the original CD which came with this Laptop?
Because you need to load the Audio divers.
If you don't have the CD then you need to go to the HP website and download the sound card drivers.
Jan 30, 2009 | HP Compaq Presario R4000 Notebook
Presario R4000 does not detect 2GB of memory
Hi PhotoTom,
I check you laptop specification and it really do support uptp 2 GB. So here I'm not sure your 1GB are both of them DDR 333Mhz ?? .If so what I really want you to test here is
1. 1 GB in one slot and turn it on (as you say you can boot wih it) after that move that 1 GB to the other slot and see.
2. try the same with the other 1GB and see that both work fine on both slot or not.
Incase both work fine on both slot then maybe problem with hardware what I want you to do after that is try to check your BIOS version and check on the website that they do have new BIOS version or not ?? Coz this can help incase problem are from BIOS.
Goodluck,takecare.
May 21, 2008 | HP Compaq Presario R4000 Notebook
Computers & Internet Logo
188 people viewed this question
David Payne
David Payne
