Question about Maytag MSD2436GR Side by Side Refrigerator
Maytag MSD 2432GR Water not feeding into Ice Maker
Water dispenser works fine, the line feeding into the ice maker has water in it but isn't moving into the ice maker. As far as I know the ice maker and dispenser work fine if they were only getting water. There is nothing pinching the line. Any ideas?
  • Anonymous Mar 12, 2014
    The water dispenser does not work. Ice maker works fine.
One possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Posted on Sep 08, 2008
Where do I find the ice maker inlet water valve or solenoid? The valve on the back of my fridge has only one hose going to both the water dispenser and ice maker and the water dispenser works fine.
Since there is water that flows to the water dispenser, the water valve is working. Now, there's a spout that water flows from to the icemaker tray. Look for it. It's located on the back wall inside the freezer and maybe behind the icemaker tray. Check and see if it's frozen. If so, defrost your freezer by turning the temperature gauge to off position. Wait a while until it's defrosted, then turn it back on.
Next, make sure that the metal wire is in down position.
If that doesn't work, your icemaker maybe defective and needs replacement.
Nov 01, 2014 | Maytag MFI2665XEM Stainless Steel
Filtered water will not dispense
If your ice maker is working your filter is fine. You need to check the solenoid valve that feeds the water dispenser. You should have 2 of them on the water line. One that feeds ice maker and one that feeds the water dispenser. That is most likely your problem
Jan 21, 2018 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge/freezer leaks water
This is not very common. If you get water coming out of the ICE maker when you press the WATER dispenser, then the thing I would check first is the solenoid controlled water valve. It might be sending water out both legs at the same time. BUT if you have had work done on it lately, I would suspect that someone didn't get the electrical leads onto the control board correctly.
Jan 15, 2012 | Maytag Refrigerators
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
Auto Ice maker in Whirlpool fridge, not producing ice. I suspect the water feed line might be frozen since it was working fine two days ago. I haven't heard the water fill and the tray is empty.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Oct 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag model MSD2756GE ice maker. Water not getting to ice maker.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
Aug 22, 2009 | Refrigerators
Ice maker sprays water...
sounds like the inlet part on the ice maker is froze over or not lined up in the opening of it right or a possibilty that the ice maker is leaking out the water if that is the case the ice maker needs replaced
Jun 07, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice Maker
The water valve appears to be the problem. The water valve ,located on rear of ref. at bottom has two (2) sides to it. One side feeds the water to the water dispensor and the other side feeds the ice maker..
Jul 07, 2008 | Maytag MSD2434GE Side by Side Refrigerator
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Dispenser not responding
On mzd2766 there is a solonoid type switch that goes bad. Could be your problem too.
Aug 16, 2007 | Maytag MSD2754G Side by Side Refrigerator
Maytag MSD2436GR Side by Side Refrigerator Logo
867 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
