Question about Danby Heating & Cooling
How to change a compressor in a DPAC7820 - Danby Heating & Cooling
    Sergeant:
    Champion:
  • 330 Answers
Do you have the tools?R-12 and R-22 freon needs special tools to fill it up.
need professional person and right equipments to do it.
Posted on Jul 06, 2008
Why do we have to replace compressor all the time???
This compressor burned out due to lack of maintenance, condenser coils were clogged 90%. compressor overheated and blow out. I made video how To change compressor and filter dryer. Its a beer cooler. REPLACING COMPRESSOR TRUE AIR BEER COOLER R134A
Apr 27, 2014 | True Refrigerated Sandwich Prep Table 72"...
Portable ac unit, hose vents outside, when the wind picks up the compressor turns off for 10 min
I have to admit, this is the very first time I have seen heard of this compliant. So, I checked the Owner's Installation Manual for your model. Not a thing was mentioned about it. So, I going to direct you to Danby's Consumer Help line 1-800-263-2629. Perhaps now, they have some type of one way damper available for this sort of situation.
I hope this helped you in some way. Thanks for choosing FixYa.
Jul 21, 2011 | Danby DPAC7820 Air Conditioner
Need a product manual for Danby DPAC7820
The model number you listed, according to Danby "has been retired" (Discontinued). However, if you contact Consumer help line: 800-263-2629, they may can help you.
Jul 05, 2011 | Danby DPAC7820 Air Conditioner
THe unit has only changed the temp from 89f to 86f in a medium size room ???
The portable AC units have a limitation when it comes to cooling a larger area, Since the unit is meant mainly to be focussed to an area it cannot be compared to the split unit or the window unit where we have the heat exchange exitting into open air. In the indoor unit the heat exchange also happens inside the room contributing to the reduction of efficiency. i would like to advice you to keep the unit closer to the exit or window. try to reduce the area by a false curtain and see if the result is good. Also make sure your filter is clean and the water is drained off.
If this makes a diffference reduce the thermostat settings to allow it to shut off and start again to prevent blocking. The AC should work bettter. Good day
Jul 12, 2010 | Danby DPAC7820 7,800 BTU Portable Air...
Air cond compressor locked up
Was it the compressor or the compressor clutch? The compressor clutch can be changed out cheaper than the compressor. So make sure you check it out before going foward with changing out the compressor.
Dec 02, 2009 | 2003 Hyundai Tiburon
Compressor runs loaded continuously even in low/no demand periods
Each compressor should be checked several times per year as to length of time it takes to fill an empty tank to set pressure. This will provide chart of performance / efficiency. I believe that compressor #2 is not running to full capacity. If compressor # 2 is suffering from leaking valves or headgasket the head and air discharge temp will higher than compressor #1. Good luck!
Oct 14, 2009 | Ingersoll Rand Air Tools & Compressors
Compressor not working
Why did you change the mother board? Was the compressor working before the change? If it was, then you need to check the new board and see if there were any wires that need to be cut when it was installed. If it wasn't running before the board change then you might try the overload on the compressor first. Also it should be checked with a compressor checker to determine if the comp is at fault or not
Sep 06, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Continues running
There is probably a stuck fan relay on the circuit board. Have a technician take a look at it to confirm this and then replace it.
Jul 08, 2008 | Danby DPAC7820 Air Conditioner
Heating & Cooling Logo
159 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
