SOURCE: magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F1
1. Watchdog on board
2. Touch membrane defective
To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board
F2
Oven too hot
Check oven temperature sensor
F3 F4
Open or shorted oven temperature sensor
Replace
F5
Hardware and watchdog circuits disagree
Replace clock assembly (also called the ERC)
F6
Missing AC signal
F7
Function key shorted
Replace touch pad
F8
Analog/Digital converter
F9
Door latch
Check door lock circuit
F10
Function key stuck
Replace touch pad F6 means no ac signal and will need to replace the oven control.
SOURCE: Broken glass top on Magic Chef range
all i want to know is how to turn on the self cleaning oven to clean it. i can't remember and i can't find the book
SOURCE: REPLACEMENT COST OF MAGIC CHEF ELECTRIC RANGE MODEL 6898XVB
you should be able to buy one for between 400 to 600 dollars new.i would check lowes or home depot to see what they have in stock.
