Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Television Our Mitsubishi WD-62527 television shuts off by itself and the lamp light indicator on the front of the set turns red. Can you tell me what the problem is? Thanks
  • Mitsubishi Master
  • 8,617 Answers
Press menu and the device buttons on the tv both in together and hold them in for 5 seconds and see if the led will blink a two digit error code, then let me know the blinks.
Posted on Jul 06, 2008
Mitsubishi TV model wd-65c9 turns itself off how can I fix problem?
l would first look to front of set when this happens---set has indicator lights that will blink (each is explained in the owner manual)
Could be Lamp, Ballast, power supply etc.
May 01, 2012 | Mitsubishi Televison & Video
I have a mitsubishi 62 in wd 62527 and the red lamp light came on and we unplugged the tv and reset the red button now no power
The red light usually means the projection lamp is bad. If you replaced it and the set still doesn't come on, then it is likely the ballast that drives the lamp is also bad. Also, if/when you do replace the lamp, make sure the access door to the lamp is fastened in properly. Other possibilities include a cooling fan failure and clogged air vents/filters. If none of these are the answer, then I would suspect problems in the power supply, usually stemming from defective capacitors which will require a technician with soldering skills to check out. Hope this helps.
Jul 10, 2011 | Mitsubishi Televison & Video
I have a wd-73833 when i turn on the tv the front blue lights come on after a minute the tv turns itself off, there is no picture
I would check your lamp 1st. Do you have a lamp light flashing on the front of your set after TV shuts down? That is a message to let you know what might be wrong.
Apr 05, 2011 | Mitsubishi WD-73833 73" HDTV
RED LAMP LIGHT!!
Check to make sure your lamp is not blown.
Make sure you installed a Mits original, and not a generic.
Make sure the lamp is seated and secured properly, as slight movement can cause a loss of connection.
Slide your set out to the side and peer into it through the slats. Can you see the lamp fire on?
Your symptom does not indicate that it could be a problem other than the lamp and the installation thereof, however---there is an instance where 2 capacitors will blow on the power supply and cause a red lamp light to show. Furthermore, the light engine itself could be causing the problems.
But, since you just installed the lamp, I would look over your installation.
Apr 09, 2009 | Mitsubishi WD-62531 Projection Television
Lamp lite
Does the lamp indicator stay yellow, or does it turn red?
May 17, 2008 | Mitsubishi WD-52531 Television
Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Sep 17, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Tv 62527 light goes off when after a few seconds when turned on
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
Jul 15, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
174 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
