Question about Haier Heating & Cooling
I bought a haier electronic control air conditioner model HWR10XC6 on 6/30/08. I installed it. When I try to use the cool mode the air conditioner will only blow out cold air for about 5 - 10 minutes and then it just blows out regular air as if its on fan. I did what the manual said to do and it still continues to do this. I can't get it to blow out cold air for a longer period. Its getting really hot in here.
    Genius:
  • 1,036 Answers
It sounds as if the compressor (that provides the cooling) is cutting out due to either a faulty thermostat or is itself overheating.
Obviously check the thermostat is able to move between it's minimum and maximum levels, anthat this corresponds to the compressor cutting in and out.
With maximum cooling selected, the compressor should not cut out untill the thermostat says it's cool enough. If it does, there is a fault, and you have every right to a refund or a free repair/ replacement.
The fault is usually centered around the compressor electrical components if it is not under any warranty, but it should be. Even if the store does not want to know, the manufacturer should back it for 1 year.
Thanks for using Fixya!
If you need to attempt repair - ask again.
Posted on Jul 06, 2008
Have a new Haier air conditioner with control panel in each room, but no manual. Can use heating, but now need cooling and unsure how to switch over
On the control panel look for mode. Press the button until you see the Snowflake symbol. That is cooling.
There is a manual at the top of this page. I have corrected your spelling of Haier in the question to help others. You should be able to get a manual from their website.
Haier air conditioner with control panel in each room Google Search
Nov 11, 2017 | Heating & Cooling
Haier a/c model esa408k-l mode is set on cool, speed set on high temp is 81 held temp button down, goes to 61 with in seconds goes back to 81.
Free Haier Air Conditioner User Manuals ' ManualsOnline ...
homeappliance.manualsonline.com > ... > Household Appliance Haier
Products 1 - 50 of 548 - Haier Split Type Room Air Conditioner Operation Manual. Pages: 0 Saves: 0 ... Haier Room Air Conditioner Installation Manual. Pages: 0
Aug 26, 2015 | Haier Heating & Cooling
Compressor stops running.
in dehumidifier modes work like in cool mode..try in cool mode too see if it work
Nov 30, 2013 | Haier CPN14XC9 Air Conditioner
Haier air conditioner won't cool the room anymore
i bought the air conditionor new and it will not cool what can i do
Jul 05, 2012 | Haier ESA406K 6,000 btu ECO-Friendly...
LOST REMOTE BUT TRYING TO GET IT COOL...PLEASE HELP!!!!!!!...its a Haier 9000 btu model #HPRB09XC7
Stephanie, the Control Panel Operation is the same as the remote control. But, if the Control Panel is not allowing you to change the settings, turn the Master ON/OFF Switch to OFF and unplug the unit for 15 - 20 minutes. Then plug the unit back in, turn the Master ON/OFF Switch to ON and set the controls as you would like. Hopefully, the unit's electronics reset themselves during the 15 - 20 minute timeout and you will be able to operate the unit using the control panel.
Hope this helped you solve the problem.
Jun 28, 2011 | Haier CPRB09XC7 Portable Air Conditioner
I was just given a Haier air conditioner model HWR05XC7. It is not manual controlled. How do you operate it?
Unfortunately, the model number you listed is not a current Haier model. However, the electronic controlled unit, use a hand held remote control to operate and set the functions of the AC unit.
Call Haier America Customer Support 877-337-3639. As the may be able to help you and provide you with an Owners Manual.
Hope this helps you. Please let me know. Thanks.
May 09, 2011 | Haier Heating & Cooling
Air conditioner not working
have you tried turning off and on power from the plug ?
Aug 17, 2009 | Haier HWR08XC7 Air Conditioner
Haier room air conditioner doesn't cool maximally at "Hi AC"
You should have at least 5,500 BTU's for that size room. Clean the filter. Turn it on and let it work for a few hours.
Aug 02, 2009 | Haier hwr10xc6 Air Conditioner
Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Dec 13, 2008 | Amana Haier AP125HD Air Conditioner
Lost Remote
go here: http://www.partlinx.com/haier.asp
andsearch for the part. You have to start with your state, and then gofrom there. For my area, the remote is 19.99, plus shipping and tax.Also, try eBay. You can find a lot of things there!
Aug 24, 2008 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
134 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
