Error code EE - Heating & Cooling
  • 1 more comment
  • Rjohnson1 Jul 24, 2008
    My Panasonic in wall AC Unit shows an "EE" error message and shuts down. I am able to reset the unit by unplugging it, but after 20 to 30 minutes of operation it again displays the error message and shuts down again. I am looking for recommendations for fixing the problem.
  • Anonymous Aug 10, 2008
    error code EE and the unit is shut down and will not work even if I unplug the unit.  The buttons don't work to reset anything either.
    donaspisak@gmail.com
I think it has something to do with the temp sense circuit of the control board, my fedders ac model a6d24e7a-e says the same thing if i bypass the temp sensing bulb with a resistor the unit will run but i do not have any way of controlling the temp, if i can find out that type of thermistor is being used i might be able to put a new one in and i will post it here
Posted on Jul 24, 2008
EE error code on reliOn blood pressure monitor?
Corrupt memory causes this.
Just guessing on your make and model type!
1 - Unplug the washer from power for 10 minutes to attempt to CLEAR THE CORRUPTED MEMORY on the main control board.
NOTE: You can try unplugging the washer multiple times to attempt to clear the corrupt memory. Unplugging the LG washer with the EE error code may clear the error code and no other action is required. The washer memory will be cleared or reset and the EE error code is considered fixed or repaired.
2 - If the code does not clear on the washer after unplugging it multiple times, this means the main electronic control board is faulty and needs to be removed and replaced.
3 - To be sure the main control board is the problem, run a TEST MODE if you want to continue the troubleshooting process or just replace the main control board and that will fix the EE error issue.
NOTE: How to run a TEST MODE on an LG front load washer is explained below...
4 - If you have unplugged the washer for 10 minutes and have done this multiple times and the EE code DID NOT CLEAR, you can run the TEST MODE and the EE error may come up with the FIRST PRESS OF START/PAUSE BUTTON DISPLAYS EE ERROR CODE. If this is the case,then you have a bad or faulty Main Electronic Control Board and you need to replace it.
Dec 16, 2017 | Washing Machines
Te 522 error EE
EE stands for Energy Efficient. The problem could be:
1) a bad thermostat 2) inadequate ventilation (blockage) 3) a bad controller board if the unit does not come on following this display.
The manufacturer pretty much decides what these specific codes mean. You might have to contact them.
Apr 07, 2015 | Heating & Cooling
I have an EE code displaying on the front
Thank you for your post, friend!
I understand that your Frigidaire dishwasher is showing a "EE" error code. However, it appears "EE" is an invalid error code. May I have you model number please? Typically you can locate your serial tag (which lists your model number) on the inside of your dishwasher on the right hand wall. With this information I can better assist you with pinpointing the issue.
In the meantime, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes. -Matt
Sep 03, 2014 | Frigidaire Dishwashers
Error code EE or E
Check your user manual, there should be a section on error codes. Most often E or EE errors are leaking cuff or improper use.
Aug 16, 2013 | Omron Hem 712CLCN2 Cuff Blood Pressure...
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
Jun 27, 2011 | Washing Machines
Eee code
error code 01 reset? indoor signal sensor
Apr 08, 2011 | Fujitsu 36CS Air Conditioner
I have a fujitsu invertor AOT54LJBYL and the key pad comes up with EEE
When EE:EE is displayed on remote control , press "Energy Save" &"Zone Control" buttons simultaneously for longer than 3 secs. The error code will then be displayed on the LCD.After getting error code, please write here to get solution. Thanks.
Feb 04, 2011 | Heating & Cooling
CODE ERROR E.EE
code will then be displayed on the LCD.Thanks.
Jan 15, 2011 | Fujitsu Heating & Cooling
Error message
EE error code with the top of the E missing is due to a faulty Thermistor.
Dec 03, 2008 | LG WM-2277HW Front Load Washer
Heating & Cooling Logo
956 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
