Question about NetGear WGR614 Wireless Router
Secured networking Right not my networking is not secured, how can I secure it?
  • 6,487 Answers
Configuring WEP:
1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
3. Click Wireless Settings under Setup menu.
NETGEAR Router WEP
4. Under Security Options, Select WEP (Wired Equivalent Privacy)
5. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
Hope that helps.....
Posted on Jul 06, 2008
Need password for 2WIRE169network connection
2. Right click WiFi Network Connection, and select Status.
3. Select Wireless Properties in the resulting pop-up window.
4. Select the Security Tab. This will show security type, encryption type, and the network security key.
5. Click the box beside Show Characters, and you should be able to see your network password.
Mar 23, 2014 | 2wire Computers & Internet
Tip
Setting up your Wireless Printer: How to check your Network Settings
To check your network settings from your computer
  • for Vista click on start then Connect To, then right click on your network and click Properties, write down the Security Type, Encryption Type & Network Security Key. ( check the box if all you see is dots)
  • for Windows 7 Click on the Network/Wireless icon on the task tray click on Properties, write down the Security Type, Encryption Type & Network Security Key. ( check the box if all you see is dots)
  • for Windows XP click Start, then Connect To then Network Connections, right click on Wireless Network Connections click on Properties then write down the Security Type, Encryption Type & Network Security Key. ( check the box if all you see is dots)
on Mar 28, 2011 | Office Equipment & Supplies
Cant find security key
If it's your router, you made the key. If it's not your router, stealing internet is a federal crime.
If you cannot remember the key then reset router to factory defaults.
Mar 22, 2014 | Linksys WRT54G2 V1 Wireless-G BROADBAND...
How do I find out my wifi password?
In Windows 7 Open Network and sharing center, on the left
click Manage Wireless Networks, right click your network and click properties, in the box that pops up click the security tab, check the box that says show characters and you should be able to see your password. Good luck!
Aug 08, 2013 | Gateway Smart Rg Sr500n Adsl2 4 Port W/...
How do I find the WPA to set up wireless connection on my new laptop
    • 1 Right-click on your network bar in the bottom right corner and click "Open Network and Sharing Center." You can also click "Start" and type "Network and Sharing Center" in the search box. Click on the Network Sharing center link in the search results list.
    • 2 Click "Manage wireless networks" on the left-hand pane.
    • 3 Highlight the network you wish to retrieve the WPA or WPA2 security key from; right-click it and select "Properties."
    • 4 Click the "Security" tab to see the security settings. The type of security will be listed along with the encryption type and security key. The security key will be hidden.
    • 5 Check the box labeled "Show Characters." The network security key will now be visible.
Apr 12, 2012 | Zonet ZSR4154WE Router
I lost my password. how can i recover it?
1: You must have a computer that is already connected to your network. Should this not be an option you can simply connect straight into your router with an ethernet cable.
2: Right click on the network notification icon in your taskbar (this is assuming you have followed step one)
XP - Select "Status"--->select "details"
Vista - Select "Connect to a network"--->right-click on [your network]---> select "status"---> select "details"
What you are looking for the IP address of your router labeled "IPV4 Default Gateway". For example mine is the same as most defaults "192.168.1.1"
You want to open a web browser (Internet explorer, Firefox (my personal preference), Netscape, etc.) and type the exact same number into the address bar. This should bring up your wireless router's setup page. Because of the amount of different hardware, this is not exact, but you will most likely be looking for a tab labeled "wireless" and then "security" or "wireless security".
You need to make sure that all of the above match between the two devices:
1. Security Type
2. Encryption Type
3. Network Security Key
4. Key index
5. Your SSID (network name) of course =)
With WEP or RADIUS the security key will be the corresponding transmit key. Anything else and you just need to make sure all the words and number match up.
Now then, Simply follow the steps for getting to the router page so you can find out what your set up actually is and compare it to your current connected network's properties
(Vista - Select "Connect to a network"--->right-click on [your network]---> select "properties"---> select "security" tab.)
Cheers if it helps! and cheers if it doesn't but you tried anyway!
Feb 14, 2011 | Linksys Wireless-G WRT54G Router
I am neha and want to do phd in computer science so please suggest me a write topic for it in the field of networking
In the field of networking you can try doing a Phd in Wireless security...
Right now there are about 3 types of wireless security, but only one type is compatible with all operating systems... But that kind of security is not more secure.... Other types of security that are more secure are not compatible with certain wireless cards...
Why dont you do a research in that...????
Any further help, comment back....
Jun 05, 2010 | Computers & Internet
How do I disable security on my Actiontech
are you sure your putting the right security wireless network key? thats the problem. check your network name and security wireless network.. thank,,
Apr 02, 2010 | Actiontec (GT701WG) Wireless Router
How to initially configure the access point
Should work right out of the box. Are you asking what type security you should set up?
There is password security, turn off the broadcast security, MAC address security and others.
May I suggest Network Magic to help you set up and maintain your network.
I use the paid pro version and love it.
Get it free - google Network Magic
Oct 19, 2009 | ASUS WL-330GE 802.11b/g Wireless Access...
Router (WGR614v6) Secure Connection Issues
you need to remove the connection saved.
after securing the wireless router, before you try to connect. Go to
-Control Panel
-Network Connections
-Right Click your Wireless Adapter
-Click Wireless Network Tab
-Remove The Network
Then Try to reconnect.
Feb 11, 2009 | NetGear WGR614 Router
NetGear WGR614 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
