Question about Car Audio & Video
Car audio system pyle pldf03rds screen keeps going blank
I have a pyle 36 backup camera when I touch the brake the screen flashes, it keeps working, what could cause this thanks for any help
Possibly poor ground at the tail light assembly.
-Check and re direct ground from the tail light assembly.
Good luck
Mai
Feb 05, 2017 | Pyle Car Audio & Video
How do I set the clock on my Pyle PLR34M mobile audio system?
press and hold DISPLAY button until numbers start blinking on display screen use volume knob to change numbers press volume knob to switch from hours to minutes press DISPLAY when done
Jul 11, 2014 | PYLE Audio NEW PYLE PLR34M IN DASH USB SD...
Screen goes blank in aux mode
Check parking brake connection. Not connected properly.
Apr 22, 2014 | Pyle PLD40MU 4.3 LCD Touch Screen Car...
My pyle plmra 220 600 watt 4 channel amp blew out, pyler said it would be 50 dollars to send it in to them so i said to heck with that and oppened her up and found a capacitor blown, but when i replaced...
outputs also blown, go to ebay and buy a better amp form the same price you would have paid for pyle to fix that one, just keep playing with that one and you will get better at repairs, thats how i learned to fix amps.
Dec 13, 2010 | Pyle - plmra220 - Marine 600 Watt 2...
I've purchased a Pyle amplifier... It doesn't work!
your first mistake is buying anything pyle..... check your remote wire that should do the trick
Apr 01, 2010 | Pyle 1800-Watt 2-Channel Bridgeable MOSFET...
What is wrong with my system
wiring may not be the problem but try connecting each coil to separate channel and make sure polarities are correct.
Aug 08, 2007 | Pyle PLA2200 Car Audio Amplifier
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
