Flashing 12 on control Panel
This come with the house recently purchased & has no manual. Can you advise what 12 flashing on the control panel means - this occurs in the start up process.
It has plenty of water, filters cleaned & 2 9.5kg gas cylinder with one replace several days ago.
  • shane_Calder Jul 06, 2008
    Rinnai Energysaver 1004 FTR
  • Richard Perkins
    Richard Perkins May 11, 2010
    Hi there!
    Please give me any makers name on various parts or model numbers to go on. I can then supply you with a users manual and troubleshoot.
    Thanks.
    Genius:
  • 1,036 Answers
This error is a Flame failure alarm.
It would be good to click HERE and print off all the alarm codes to keep.
As you've just put new gas on, you will probably have to purge the system of air before you get any gas through.
You can probably do this at the heater end.
You first need to check you are getting a spark to the pilot.
If not, check electrical connections, and trace fault to the ignition assembly.
If you are getting a pilot flame (unlikely as you're getting an alarm), you will need to concentrate on the hot-wire sensor and check if it is faulty.
Thanks for using Fixya. Please rate if this works for you.
Posted on Jul 06, 2008
Control panel is flashing 'O/D Off' what does this mean?
that means your over drive is off. which means the over drive shift solenoid need to be replaced
Dec 28, 2012 | 2002 Lincoln Continental
2004 chevrolet suburban service engine light flashing - what does this mean?
If you have - or can borrow an OBD tester - down load the diagnostic codes and check in the manual for their meaning. You can also shunt the dianostic port with a wire and read the flashes off of the instrument panel to see the codes being flashed and find their meaning in the appropriate service manual (this manual will also tell you how to properly shunt the dia port). A GM dealer will sometimes advise on this.
Nov 23, 2010 | 2004 Chevrolet Suburban
How to reset house alarm after power cut
alarm may be in battery back up mode when power is lost it will automaticly start running off these batteries that are usually located in the panel. diffrent devices have diffrent ways or restoring regular mode. i would contact the maker.
Feb 27, 2010 | Lorex 4 Channel Business & Home Security...
Flashing red ''M'' all over Screen
As you have only recently purchased the TV and it is misbehaving right in the begining, then I suggest that you return and replace it with another piece. Or another brand if possible.
Nov 08, 2009 | Element Electronics ELCHS371 37 in. LCD TV
I am needing an instruction manual for rinnai energysaver 556/FTR as have purchased and moved into property recently and am having trouble operating the heater and am concerned with a red filter light that...
www.rinnai.co.nz
navigate to tradesmart, space heating, energysavers.
Red filter light means the filter is blocked.
its located directly on the back of the heater and the wall spacer, from the control panel, its about 4 inches back.
Pull it up, clean reinstall
Apr 27, 2009 | Heating & Cooling
Chef regency oven with "HELP" flashing on panel. Have no manual
Usually means that the time needs to be set. Press Clock Set then use the up and down button to set correct time, Then press Manual button.
Apr 16, 2009 | Ovens
Auto transmission
The Gearbox Control Unit Is Defective Inside The Rear Of The Gearbox
Jul 07, 2008 | 2004 Audi A4
Flashing lights on black and colour ink cartridge indicators
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokl-26
Jan 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
