Question about Brother CS-6000
Hand wheel won't turn
My Brother CS 6000 is about 1.5 years old. My son recently used it to hem his pants and when I went to use it, it won't work. It did have a thread jam in the bobbin case. I could not and still can't get the bobbin case out. I pulled all the thread out and the bobbin case still won't come out. I couldn't find a screwdriver small enough but with enough strength to loosen the screw on the faceplate to see if there is anything else in there. I kept testing the machine to see if I got all the thread out by pushing on the foot pedal It shudders and the needle tries to move but then it just locks up. That is when I noticed that the hand wheel was not moving. So I don't know which came first or which is causing the problem.
I continued to try to get the bobbin out. I finally decided to break it out. Once it was out I tried pulling the case out so I could see if anything was jammed underneath. It took a lot of work but it finally popped out like the manual said it should. I cleaned it out, nothing really dirty, no thread jams. When I went to put it back together I noticed that the way to put it back was not the way the case was sitting when I took it out. So I figure that my son must have jammed it and somehow knocked the bobbin case out of alignment. I put it back in correctly and it works just fine now!
Posted on Jul 08, 2008
I am trying to find out how to put part of a sewing machine back together that was taken apart. It is a cs 6000! computer sewing machine Brother. The rod that goes up an downthat holds the needle has
There are three types of CS 6000 they are CS 6000B, CS 6000i and CS 6000T
You can download the service manual and parts manual from this site
http://www.nodevice.com/manual/Brother/page2.html
One file costs 4.95 Euro, or a 24 hour download (better value as you can get the parts manual too) costs 7.95 Euro to download
Oct 02, 2014 | Brother CS-6000 Computerized Sewing...
My brother started making a loud noise when sewing pant fabrics
Your machine is complaining because it doesn't have the power to push through the layers of fabric. That clunking noise is the gears in the machine skipping and being sheered off (or it will be eventually) STOP!
If you feel that you need to continue... stop when it does this noise and use the HAND WHEEL. You'll also need to make sure that the presser foot remains level while going over thick seams.
Jan 02, 2013 | Brother Sewing Machines
How do I fix the E1 error code?
Abnormal rotation in main motor Motor runs at more than maximum speed
Look HERE for Service Manual
May 22, 2012 | Brother CS6000i Computerized Sewing...
No manual, not sure the year either...:( I have a new home memory craft 6000-- and I can not for the life of me thread the darn thing..... there is a bobbin underneath no clue what I am doing... I need to...
This is same thing as a Janome Memory Craft 6000 (called New Home in UK I think) so why not buy a manual for it, they usually run to 100 pages and are well worth having to best maximise your use of the machine and prolong its life by properly maintaining the machine.
Here is link to a photocopy of this manual on www.sewingpartsonline.com
http://www.sewingpartsonline.com/instruction-book-janome-and-newhome-6000.aspx
Or you can buy a copy on this website
http://www.sewusa.com/Sewing_Machine_Manuals/New_Home_Manuals/New_Home_6000.htm
The top loading bobbin will have a tension spring on the side that you need to "click" the bobbin thread into so it is tensioned. There is usually a little crack that the thread goes down into, its a case of holding the thread tail with your right hand, placing a finger tip from your left hand onto the bobbin to hold it still, then press down on the thread tail with another figer so it clicks in
to the tension device.
Then place cover plate back over the bobbin leaving the thread tail hanging out and do the usual "lower the needle" down then back up to draw the bobbin thread up to the needle plate.
Top threading up should be fairly obvious, always do with the pressure foot raised and pay attention to the tension dial and the thread take up lever, all machines have these two points to manipulate the thread and then some thread guides to take the thread down to the needle. I just can't find a threading diagram for this machine online to refer to but Janomes are very similar so if you go to http://www.sewusa.com/Threading_Diagrams/Threading_Pages/New_Home_Threading_Diagrams/New_home_2022_Threading_Diagram.htm
and take a look this may get you going.
Hope this helps you out with the 6000, 4 thumbs up if so.
PS, I always hand hem trousers myself, I just overlock the raw edge first for neatness. If there is hardly any hem allowance, then I will stitch on a piece of bias binding to cover the raw edge, then turn this up and hand sew it.
Aug 30, 2011 | Sewing Machines
Where can i buy an electrical cord and the medal cord for my brother cs 6000 sewing machine
Call Brother at 1-877-276-8437 and order it direct from them, or go www.sewingpartsonline.com and buy from them, the foot control costs $29.99 and the power cord costs, $13.99 from Sewing Parts, I don't know what Brother's price is, but you can compare. Happy New Year
Jan 03, 2011 | Brother CS-6000
Sewing hems on pants without stitch showing
you want to use a blind stitch. Refer to your manual and it should give you details on how to set the machine for that stitch.
Apr 05, 2009 | Brother XL-3510 Mechanical Sewing Machine
Frozen machine
Hi this is techcrazy
the motors in ur sewing machine is not runnin because there is no proper rotational motion inside the motor of sewing machine.so one way of rectifyin is replacing the old pair of magnets with new ones..which may prove costly.so if possible my sincere advise is to go in for a new one
please do rate me on this solution
Feb 02, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Brother Innovis 4000 D stopped sewing
These machines are known to freeze up in the needle bar crank, even when only a couple of hours old. If it is less than a year old, a Brother certified service center will fix it under warranty.
Jan 29, 2009 | Brother CS-80
Brother CS 6000
With the foot pedal disconnected from the machine, push the button with the - and upward arrow. to stop sewing use the same button. It is the first button closest to the needle.
Jul 29, 2008 | Brother CS-6000
Cant hem unable to workout what length to start with to end up with the correct length required looking at the manual it says to take the hem and fold it over etc. but its very confusing
Sorry, I don't understand just what you mean by "length to start". Length of what - stitch? hem turn-up?
Let us assume you are taking up a hem of a pair of pants. Try them on and put a pin where you want the hem to finish i.e. this will be the bottom of the pants. Take pants off, turn them inside out (careful that your pin does not fall out!) and fold the excess pants on that pin mark. The excess fabric should be on the outside, not tucked inside the leg tunnel. Measure how much it is from the existing hem to where you folded it over, let us say for the purposes of this exercise it is 4 inches. Your hem is to be 1 inch and you need 1/2 inch to turn under for a neat finish, total 1 1/2 inches, so you need to cut off 2 1/2 inches from the bottom of each pants leg. Fold 1/2inch at new leg bottom (wrong side of fabric to wrong side), press, fold 1 inch hem same way and press. Place pins every 2inches or so at a right angle to the hem edge. Pins should come out 1/4inch from edge of hem where the 1/2inch neatening fold was made (this is where I wish I could draw a picture!). Fold the hem back inside the leg tunnel. The pins should make the fabric fold under only enough so that 1/4inch of the hem sticks out beyond the pants leg. You will sew on this bit using the blind hem stitch (04 on my 7550). You might need to adjust the stitch width - not length - so that the straight part of the stitch goes along the hem bit and the zig-zag JUST bites into the pants leg fabric.
I do hope this lengthy explanation is of some use to you!
Jul 01, 2008 | PfaFF Creative 7570
Brother CS-6000 Logo
190 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
