Question about Apple iPod MA446LL/A MP3 Player
Ipod mini 4gb 2nd generation centre button failure
Hi everything works fine except the centre button so i cannot scroll through any of the menus etc what can i do thanks from sandra
  • 8,596 Answers
Make sure the hold/lock is not engaged
Then reset the player
If the center button still doesn't work, get the player exchanged b/c it's broke
Manual and contact info available from Apple website
Posted on Jul 06, 2008
Why can't i view my songs on my ipod?
Hi Cynthia
You have done well keeping this iPod working this long as this device is now Obsolete. Hopefully you have a backup of all your music. This is one of the older iPods that use an internal Hard Drive. This is usually the part that goes first as they are spinning while in use. More modern devices use Semiconductor Storage like a USB memory stick.
Have you tried holding down the reset keys to completely restart the iPod.
Reset
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again)
Press and hold the Menu and Centre (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
SUPPORT www.apple.com/support/ipodmini/
Further INFO
At MacWorldExpo in January 2004, Apple introduced iPod mini, shipping in a smaller form factor and five different colors (silver, gold, blue, pink, green) with a capacity of 4 GB. iPod mini was sold for $249 US
If this was Helpful please click the button!
Jun 29, 2014 | Apple iPod Mini A1051 2nd Generation 4GB...
My Apple iPod Mini won't play or connect to the PC. It displays the charging symbol but isn't recognised by any PC. It also displays the sad face once charged, and then 'do not disconnect' sometimes. I've...
Yes you must do a reset.
Turn the lock switch off.
Hold down the centre button.
Press and hold down menu.
When the Apple logo appears let both buttons go.
Should then work properly.
Jun 28, 2009 | Apple iPod mini 2nd generation MP3 Player
I changed my Ipod mini battery. When I got it all back together, it was working except it was locked and I couldn't get it unlocked. I flipped the button back and forth several times trying to get it...
try this... plug ipod to pc/laptop let it open itunes.....once ipod shows up ......disconnect.........it should be unlock..
if not....this one you are best to make sure all of files are on itune, because if you do this it will unlock the ipod and also delete all of your files....(factory restore)
Jan 27, 2009 | Apple iPod mini 2nd generation MP3 Player
Ipod mini syncing
I am having great success with a Dynex brand usb cord on this model. Is your computer running Windows Vista by any chance? You may need an extar driver from Apple's website if this is the case.
May 23, 2008 | Apple iPod mini 2nd generation MP3 Player
I connect Ipod to computer it will not sync
Try resetting the iPod, this usually works.
As follows:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
http://www.pchelpforanyone.blogspot.com/
Mar 10, 2008 | Apple iPod nano
I pod freezes after initial start up
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Dec 05, 2007 | Apple iPod MA446LL/A MP3 Player
Won't start.
  • iPod classic
  • iPod nano
  • iPod mini
Dec 04, 2007 | Apple iPod MA446LL/A MP3 Player
Ipod Nano Second Generation
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Aug 24, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
Apple iPod MA446LL/A MP3 Player Logo
23 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
