Question about Lands Phones
Having problems pairing my blackbery8310 too my 320 plantronics earpiece. my blackberry picks it up but then asks me for a alphanumeric password.My question is am i supposed to pick it outor does it come with one in the package?ive tried picking one out myself but then it says unablke to pair?thanks so much amy
  • 4 Answers
The default for most bluetooth pairable devices is 0000 and generally this number cannot be changed. This is the number you should use.
lowercap
Posted on Jul 24, 2008
  • lowercap Jul 24, 2008
    Should have joined before i pressed the darn button.
Hello I am trying to install a new headset to my CS70 desk phone. The ruber earpiece on mine broke. How can I pair the new earpiece?.
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone, PC or other device for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your other device to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
Oct 14, 2010 | Plantronics CS70 Wireless Headset
Tip
How to pair a Plantronics Explorer 245 Bluetooth headset and a BlackBerry Tour
The Plantronics Explorer 245 headset can be paired with most Bluetooth-capable phones and smartphones to enable hands-free phone conversations. To pair the headset with a BlackBerry Tour, follow the steps below:
Make sure the Plantronics headset is off before trying to pair the two devices. On your BlackBerry, scroll down to Manage Connections (the antenna icon) in your Home folder and click the trackball. From the list of connections, select Set Up Bluetooth. The Add Device box will appear, asking if you want to search or listen for a Bluetooth device.
At this point, turn your Explorer 245 on by sliding the on/off switch toward the microphone end of the earpiece. Once the device powers on (if you have it in your ear, you'll hear a few short tones) you should see repeating red and blue flashes from the LED lights on the side of the headset. If you only see blue flashes, hold down the call button (the side button) for a few seconds, until the lights start flashing red then blue.
Now, on your Tour, select Search. Bluetooth will be enabled if it's not already, and then the BlackBerry will search for nearby devices. When the headset appears on the list of devices found (it should read "245Plantronics" or something similar) select it. A box will appear letting you know that pairing is now complete, and asking if you want to connect to the headset. Select Yes.
Your BlackBerry Tour and Explorer 245 are now paired. If at any point you turn the headset off, turn the BlackBerry off, or turn the BlackBerry's Bluetooth feature off, the two devices will automatically reconnect when they are able. When you look at your list of paired devices on the BlackBerry, the Explorer headset will appear in bold to show that it is currently connected.
on Oct 26, 2010 | RIM BlackBerry? Tour 9630 Smartphone
How to connect plantronics 330 bluetooth headset with my iphone 4
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
Jul 20, 2010 | Plantronics Explorer 330 Headset
Where do I find the passkey?
the number is 0000 this is a basic passkey for all bluetooth devices.
Jul 09, 2010 | Plantronics Explorer 220 Bluetooth Headset...
How to connect my Nokia E71 with Plantronics 330?
Mar 22, 2010 | Plantronics Explorer 330 Headset
I can't pair my plantronics 510 BT earpiece to my new bold 9700. but I can pair to my old BB and can pair other stuff to the 9700, so know that both devices work...just not together.
You might want to check which version of the the BlackBerry system software you are using.
Having the latest version will ensure that you are running a platform with as many bugs worked out as possible.
This page will provide a link to the latest multi-language version of BlackBerry System Software.
Mar 02, 2010 | RIM BlackBerry Bold 9700 Smartphone
Need help pairing
Feb 28, 2010 | Plantronics Explorer 330 Headset
Unable to pair bluetooth Plantronic 975 with BlackBerry 9700
On your Blackberry, navigate to Options,Bluetooth,Hit the cursor, Select Options, Set Discoverable to Yes, and save.
Make sure your Plantronic is in pairing mode.
On the Blackberry, hit the return key, add device, Search, Pllantronic will be listed on the blackberry as found. Select it, and add the password which by default is 0000.
Feb 10, 2010 | Cell Phones
I am trying to pair my Plantronics Explorer 330 headset to my new phone, an HTC Eris. the phone does not recognize the device. Do you have any ideas?
Dec 21, 2009 | Plantronics Explorer 330 Headset
Plantronics Explorer 220 no longer connects to Blackberry Curve
You can have the two devices connected, but still get your sound through the phone. During a call (maybe call your voicemail or an automated number, just to make a call) try holding down the answer/end button on the earpiece until it beeps, and see if the sound switches from the phone to the earpiece. You can also try pressing the speakerphone button on your phone during a call to switch the call to the earpiece.
Did either of those ideas work?
Jan 26, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Lands Phones Logo
71 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
