Zenith DVT412 I was moving my Room around. I reset is all up and it worked fine. Then I did progressive scan and now I get no signal to my tv. I checked with other tv. I get sound, no picture. Can you help?
If you are using analog video output to connect to your tv set and accidentally selected progressive scan from the setup menu you will loose the analog signal output.
Turn the unit on with no dvd inside and after the " no disc" message press stop (on the front pannel button) holding it for about 5 seconds. It will restore the original progressive scan configuration (value= no).
Posted on Jun 14, 2009
I didn't realize there is a separate hook up in the back for progressive scan. I switched the wires in the back from the tv to dvd and all was fine. Oops!
Posted on Jul 07, 2008
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
Sound but no picture. Not progressive scan issue I think.
Have you tried swapping the scart lead ends around, this might work.
Mar 23, 2010 | Zenith DVT412 System
I cannot get video picture,But ican hear all audio functions.
put a disc in the player and once it starts to play press stop, then press and hold the stop button for 5 seconds this will turn off the progressive scan feature.
Apr 26, 2009 | Zenith DVT412 System
I accidently hit the progressive scan button and now I can't get a picture when I try to watch a dvd.
just talked to LG Customer support and got them to send me a manual.
to turn off the progressive scan insert a disk and once it starts playing press stop, then press stop again and hold for 5 seconds this will turn off the progressive scan mode.
Dec 09, 2008 | Zenith DVT412 System
Stuck in progress mode help
Try this without disc on the tray press the button stop for 5 seconds.Good luck
May 24, 2008 | Zenith DVT412 System
Zenith DVT412 System Not working at all
Hello Nibas,
You may have damaged the laser diode or one of the biasing components, you will need to take this to the shop to have it repaired. This is due to the fact that the laser output has to bee measured and you don't have the equipment to do that. This is not a case of resetting the DVD player which on this unit only covers if the unit is in progressive scan mode (how to reset from progressive scan). I know this is not what you may have wanted to hear but it is the truth. In any event you will have to take this unit to a repair shop.
I hope this helps,
Thank you,
Shuttle83
Dec 31, 2007 | Zenith DVT412 System
Progressive scanning issues
thanks it help me very much
Aug 23, 2007 | Zenith DVT412 System
My home theater got stuck in progressive scan mode
I had this problem, it's a real pain. You need to turn the system on and goto Setup Mode, then count the number of tiems you would need to scroll down and reset it. You will see no picture, so you ahve to actually cound the number of clicks down and over, you are doing it blind, but it will work.
Sep 07, 2006 | Zenith DVT412 System
Turn off progressive scan mode
If you set progressive scant On by accident,you must reset the unit. Remove any disc from the unit and close the disc tray. See that "disc" is displayed on the display window. Now press STOP and hold it for more than 5 seconds before releasing it. The video output will be restored to the standard setting and picture will once again be visible on a conventional analog TV or monitor.
Sep 05, 2006 | Zenith XBV443 DVD Player/VCR
No picture but has sound
Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
Aug 14, 2006 | Zenith DVB312 DVD Player
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
