Machine stuck on test programme - Washing Machines
    Novelist:
  • 177 Answers
Unplug it and let it sit for about five minutes, this should reset it.
If it does not you may need a new control.
T
Posted on Jul 07, 2008
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
The washer programme has frozen and stuck on a cycle. how do i reset programme?
try unplugging the machine for 10 minutes,plug it back in and see if it will reset,if not you could have a button stuck inor a bad touch panel,send the model number next time located around the door opening.
Nov 28, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint ultima wf860 washing machine when trying to do a wash it just keeps saying test what is wrong with it ?????
SomeHotpoint's are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see 'D:end' (or similar message). Now try a normal wash programme again and hopefully it should be fine. If it goes into test mode by itself, then it may be an indication that there is a real fault, or a faulty programmer board. hope this helps.
Sep 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
WF220 Hotpoint - burning smell + wash cycle stalls?
The burning smell is coming from motor. Also your clutch is bad where you are hearing the rattle/grinding.
Dec 12, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Programme gets stuck on wash cycle
Most likely a defective door switch.
Mar 02, 2009 | Washing Machines
Hotpoint aquarius
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Oct 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing machine
I have had this problem and have found the solution elsewhere in this website. You need to hold down the on/off and the start/cancel buttons together for a few seconds.
Nov 01, 2007 | Hotpoint Washing Machines
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
