Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Sony KDF50WE655 Projection TV/ Blue line
This TV is a 2005 and is working fine until recently. I noticed a light blue line from the left side to the middle of the screen. Sometime it is very noticeable. Is there a fix or adjustment?
  • 3 more comments
  • Anonymous Aug 30, 2008
    I have the same problem but on the right side. Called Sony, and they offered to sell me a replacement 52 in flat panel for only 700.00. That's a 1500.00  cost savings over any other out their. I jumped at it.
  • AZonie Sep 04, 2008
    I've had the same problem with my KDF-50WE655. If you do enough research on the web, you will discover that Sony is aware of a problem with the optical block (the heart of the TV) an $800+ repair and will work with owners to remediate until December 2008. They will offer to fix the problem at their cost or offer a new replacement LCD flat panel for a fraction of the new cost. I jumped on the new LCD replacement offer - but you better act fast!
  • Anonymous Oct 09, 2008
    KDF 50WE655 (50”wega projection LCD TV)
    Washed out center of viewing area, blue areas across the bottom and right lower corner of the screen, five blue dots on screen (two of the dot sometime leaves and then comes back.
    Problem began the weekend of 9-20-08.
    Option1: Repair under call back, known problem.
    Optical block, light engine
    Option2: buy out with replacement TV
    Peel serial number and mail to Sony
    (1) KDL52W4100 (52” LCD)
    (2) KDL52V4100 (52” LCD)
    (3) KDL46Z4100 (46” LCD)
  • Anonymous Oct 16, 2008
    My blue dot was in the lower left hand corner which later graduated to many smaller, pea-sized blue dots scattered across the screen. Web research shows a cost of $800 to repair. Sony offered to repair or sell its latest LCD for $800. The old set had approximately 7000 hours of use over 3 years old. Needless to say, I jumped to buy the new set. So far I am pleased with the new one.
  • Anonymous Dec 26, 2008
    I am running into the same problem - blue streak running entire bottom quarter of the screen.
    Did you need to have a warranty for the replacement LCD?
experttv
  • 203 Answers
SOURCE: sony KDP57WS550 Projection tv red, green and blue virtical outlines on left and right sides
This is a convergence problem. You will need the stk's changed and a pico fuse or 2. also from looking at the pic you might want to clean the lenses and mirror after the repair to bring back some of the vibrant colors the set once had when it was new. This repair should run you anywhere from $300-$500 depending on your area and the tech that comes out. If you need more information or would like to try to fix it on your own please let me know.
Tim
Posted on Sep 11, 2008
SOURCE: Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Posted on Jan 19, 2009
  • 41 Answers
SOURCE: We have a sony wega KFWS60.
Do you mean KF60WE655. I don't recognize the model you show. I'm sure your talking about an LCD rear projection Sony. Your trouble is in the Optics ( light engine). Over time the Lamp has destroyed an internal filter ( glass element ) . This Blue haze or film will probably continue to get worse and grow across the entire screen. The only fix is to pull out the Optics and send off to Sony or another re builder.
Up until June 30, 2008 some of these models were being fixed at no cost by Sony.
Posted on Apr 16, 2009
ssebata paul
  • 159 Answers
SOURCE: sony grand wega KF-60WE610,blue dot in the middle of the screen
check focus ic
Posted on May 30, 2009
SOURCE: Arched blue lines across screen of Sony 63" Rear Projection TV
Had this problem bout 2,3 years ago...it was fixed in about 5 minutes with the help of this article
Tonight I have to do this fix again..the blue lines came back about a week.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
I strongly urge you to save the web page locally on your hard drive or print it out and place with the tv manual....
Good Luck..
Posted on Jun 19, 2009
Toshiba Model 51h84
The wavy when cold is a issue with a board in the set--Hyper board--the warmup until it begins to work will gradually get longer and longer.
The blue: look at set on a unused video input--if see faint curved blue lines with some blue visable on the screen the blue screen control needs to be adjusted just slightly down until the blue and curved lines are not seen.
May 15, 2012 | Toshiba 51H84 51" Rear Projection...
Tip
Blue Blotches, blue stars, blue dots in picture
This is caused by a bad optical block. Sony has extended the warranty for parts and labor to cover this problem until December 2008. You can find additional information and how to obtain service here:
http://ciscdb.sel.sony.com/perl/news-item.pl?news_id=206&mdl=KDF50WE655
on Nov 13, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a sony kdf50we655 TV. Over the last 12 months, the picture has been increasingly "pixelating" with royal blue dots. It started with the lower right corner of the screen fading from black...
This is not a LAMP issue, it is much more serious than that, you need to have it checked by a certified technician, it sounds like the image prossessor
Jul 27, 2011 | Sony Televison & Video
I have a 42 in Sony HDTV model # KDF-42WE6555. I notice a few months ago a blue line down the left side. TV still wking good. Today I notice a yellow patch on the right side. TV is still wking good except...
i have the same problem but mine has a blue line surrounding the screen the tech took out the fly wheel part from inside this part has the 3 main colors with strips the blue side strip if you look at the glass it has the problem you see on your screen you have to replace that one section
Mar 10, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Blue dots on the screen and blue flame on side of tv screen
See this page:
Sony is covering the repairs of this problem under warranty. It is caused by a bad optical block. Go to the above page to find out about getting it repaired. Be sure to rate this solution. Thanks!
Nov 10, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony screen image distortion.
see this:
Looks like your model is covered till December 2008
Please be sure to rate this solution. Thanks!
Nov 07, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have blue botches ( ghosts ) appearing on the tv
This problem is caused by a bad optical block. Sony has extended the warranty for this problem but the extension is only valid until December 2008 so you must act now. You can find instructions for obtaining service and additional information here:
Oct 25, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
157 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
