Question about Microsoft Xbox 360 Console
My xbox 360 wont turn on
I was playing my xbox 360 one day and i turned it oof and took the plug out then when i pluged it back in the yellow lite turned on but nothing happend when i presd the button to turn it on
    Problem Solver:
  • 7 Answers
Make sure ur power brick is plugged in correctly. when u tur n ur 360 on the lite on it should be green
Posted on Jul 06, 2008
My xbox 360 says play dvd when i put some games in....what should i do
What i did was just simply took the disc out then turned it offf pulled out all wyers wated 10 secs then pluged it all back in turned it on and put the same game in then it worked
Jul 06, 2010 | Microsoft Xbox 360 Console
Hi there, when i turn on my xbox 360 i can here the audio but cant get any picture. What can I do to fix this problem?
Try this as it worked for me.
First i took off my hard drive on the 360. Then i pluged it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) i only say this because i didn't use the HDTV setting to fix it. then i pluged it into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on i took 1 towel folded it long ways and wraped it around my 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. mine has been working for 3 days now with no problem i even have it hooked up using the HDTV cables in my living room.
Mar 21, 2010 | Video Game Consoles & Games
When i connect xbox 360 arcade[new] to my tv can't it to play
have you switched the switch to hdtv and NOT tv on the back of the big grey ariel plug going into your 360 ? then turn your tv to the aux or av channel as it wont be on a normal channel ??
Jan 26, 2010 | Microsoft Xbox 360 Console
My xbox 360 wont show a picture but it has sound
This is how to fix it. So here is how you do it. First i took off my hard drive on the 360. Then i pluged it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) i only say this because i didn't use the HDTV setting to fix it. then i pluged it into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on i took 1 towel folded it long ways and wraped it around my 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. i hope this will help u....pls rate...cheers...
Jan 05, 2010 | Microsoft Xbox 360 Console
Xbox wont turn on its pluged in and getting power to the unite but wont turn on
What color is lit on the power unit? Is it red, yellow, or green? Are you using a wireless controller to turn it on or the actual button on the XBOX? If you're using the wireless, make sure it's plugged in to the unit and controller. If not, replace batteries in controller and see if that works. If still nothing make sure you have a good connection between the power unit and the XBOX.
Dec 06, 2009 | Microsoft Xbox 360 Console
I have sound,but no picture
check to see if your coords are plugged properly if so it could just be the coords might need new ones
Jul 27, 2009 | Microsoft Xbox 360 Console
Xbox 360 wont work on my Tv now - always been fine before
Hi...
Make sure the switch on the 360 A/V cable is in the right position. Also unplug everything from the unit and plug it all back in again.
From the reading I've done on tech issues the 360 has a lot of temporary issues like that.
Jan 02, 2009 | Microsoft Xbox 360 Console
Xbox 360 is on , but no Picture/Sound
DO NOT USE THE TOWEL ONE!!!
THE TOWEL ONLY HEATS IT UP MORE AND THE 2 X CLAMPS INSIDE WILL VIBRATE ONLY 2 MAKE THE MAIN XBOX CHIP 2 COME OUT OF ITS PLACE.... SO THIS IS WHAT U DO!!! First Get a Screw driver and take out the covers of the xbox and ull see a metal sheeting. Then take out all the screws from the metal board. then take out the other things (take out the fan last) Then If its the graphics chip thats broken then u need a new one but if its out of place, replace it and put the xbox bak 2gether. The  the prob shud not happen again. This is what happened 2 me only last week. it shud only take 30 mins 2 fix.
But the other prob could be the cord cause the cord might be old faulty or broken cause my friend had dat prob.
Dec 18, 2008 | Microsoft Xbox 360 Console
Audio but no video when i turn xbox 360 on
hi MC, power off unit unplug av cable from back of xbox.. then power up unit.. after a couple minutes the xbox will shut down.. plug the av cable back in and power up.. Good Luck
Jun 30, 2008 | Microsoft Xbox 360 Console
XBOX 360
check connections.
e-mail me at B3652@live.com
May 31, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
83 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
