Question about HP JetDirect EX Plus Print Server
How to setup JetDirect Plus (J2591A)
Have a J2591A that was given to me. Trying to connect a HP LJ6p to my DSL modem/router (Westell 327W). Do I hook it all up and then run the software (downloaded from HP)? Tried it a while back, couldn't get to J2591A to set IP address. How does one do this?
TIA
Sam
  • Anonymous Mar 02, 2009
    My HP JetDirect EX Plus Print Server is set up for DHCP and IP Add: 0.0.0.0 .subnet mask: Not Specified.DHCP server: 0.0.0.0
    Now how can I setup my static ip address
    Sniper:
  • 87 Answers
Hi Sam,
I had a similar problem and solved it, so here is a step by step. Connected to a Linksys 54G wirekess router/hub it works fine on Vista and XP, the approach is the same but some windows might look different. You may not even need the HP software at all, as Windows recognizes the HP JetDirect. Also, depending on your PC software configuration, e.g Firewall settings and router settings you may have to permanently permit various communication request. The steps below are to be understood as a guide line and may vary form yours as there are different ways to achieve the settings. On Vista, Telnet is disabled by default and needs to be enabled frist. On XP telnet is enabled by default. If you use a Linksys or similar router, you may need to enable DHCP for some addresses or range that will be used. In such case see you router manual how to do that.
Step 1:
you need to know what your LAN address is, to find out you can open a DOS window and enter IPCONFIG, this will give you the current IP address and subnet mask. On a small home network it may be 192.168.1.xxx and sbunet mask may be 255. 255. 255. 0, yous may be different. Take note of these values (IP: aaa.bbb.ccc.ddd) as you will have to set the HP JetDirect J2591A to the same address range.
Step 2:
connect the printer to the HP JetDirect, have paper in the printer, power the HP JetDirect and hold the test button on the HP JetDirect for about 7 seconds, the printer will then print the current HP JetDirect settings. You may notice the address range the HP JetDirect is set to may not be the same address range as you need it to be (your noted once)
Step 3:
connect a PC computer directly to the HP JetDirect using an Ethernet CROSSOVER cable OR connect a PC via a hub and tow standard Ethernet cables to the HP JetDirect.
Step 4:
TEMPORARELY change this PC computer network address to the same address range as the HP JetDirect address range (www.xxx.yyy.zzz) currently is set to and reboot the PC.
Step 5:
after reboot, the Status LED on the HP JetDirect should be solid on and the activity LED should be off or flashing occasionally, idicating some network traffic. Open a DOS window on the PC and run a telnet session by entering TELNET www.xxx.yyy.zzz [ENTER]. You may have to hit the Enter key tow times for a connection to start. You will then see a screen as follow:
Please type [Return] two times, to initialize telnet configuration
For HELP type "?"
===JetDirect Telnet Configuration===
Present Config : DHCP
MAC Address : 00:60:b0:ab:cb:4e
IP Address : 192.168.1.8
Subnet Mask : 255.255.255.0
Default Gateway : 192.168.1.1
Syslog Server : 0.0.0.0
Idle Timeout : 90 Seconds
Set Cmnty Name : Not Specified
Host Name : HP_PRINTER_SERVER
DHCP Config : Enabled
Passwd : Disabled
Novell : Disabled
DLC/LLC : Disabled
Ethertalk : Disabled
Banner page : Enabled
To Change/Configure Parameters Enter:
Parameter-name: value <Carriage Return>
Parameter-name Type of value
ip: IP-address in dotted notation
subnet-mask: address in dotted notation
default-gw: address in dotted notation
syslog-svr: address in dotted notation
idle-timeout: seconds in integers
set-cmnty-name: alpha-numeric string (32 chars max)
host-name: alpha-numeric string (upper case only, 32 chars max)
dhcp-config: 0 to disable, 1 to enable
novell: 0 to disable, 1 to enable
dlc-llc: 0 to disable, 1 to enable
ethertalk: 0 to disable, 1 to enable
banner: 0 to disable, 1 to enable
Type passwd to change the password.
Type "?" for HELP, "/" for current settings or "quit" to save-and-exit.
Or type "exit" to exit without saving configuration parameter entries
Step 6:
Now you can change (likely neccessary) the HP JetDirect settings, make sure the HP JetDirect IP address is in the same range as you need it to be (for example aaa.bbb.ccc.25), also be sure to set the DHCP Config to Enabled. Optional you may want to enter a Host Name, for example: HP_PRINTER_SERVER, once you are done these new settings must be saved by entering 'quit' [Enter]. You may want to repeat Step 2 and print the new settings to convice youself the settings are retained and correct. (power cycle the JetDirect of course)
Step 7:
Connect your HP JetDirect to the intended network.
Step 8;
On the PC used to do the HP JetDirect configuration setup, restore the PC's initial network IP sddress and reboot it so it can be used again with its original settings.
Step 9:
On a PC connected to the same network as the HP JetDirect, open a DOS window and run a ping by entering: ping aaa.bbb.ccc.25 [Enter] depending on firewall settings you may have to grant permission to allow the ping to come through. You should then see a screen similar to this:
C:UsersHW_Dude>ping 192.168.1.8
Pinging 192.168.1.8 with 32 bytes of data:
Reply from 192.168.1.8: bytes=32 time=5ms TTL=60
Reply from 192.168.1.8: bytes=32 time=3ms TTL=60
Ping statistics for 192.168.1.8:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 3ms, Maximum = 5ms, Average = 3ms
C:UsersHW_Dude>
Note, there are 4 packets send and received without any loss. This is what you expect to see and great confirmation the HP JetDirect is on the network and ready. If you don't get that then there may be an issue with cabling and/or the firewall settings, you may want to double check these in such case.
Step 10:
On any PC connected to this network one can now insatll/connect to the printer that is connected to the HP JetDirect, using the Windows Add Printer Dialog, click to open the add printer wizard. Check the button for LOCAL printer (yes local, not networked !!! Who would have thought of that !? Thanks Bill G.) On the next screen that opens check the 'create new port' option and select 'Standard TCP/IP Port' OR (if available) 'HP Standard TCP/IP Port) and ckick Next. Another windows opens with TCP/IP setup wizard, click Next. An window opens, enter the HP JetDirect IP address (aaa.bbb.ccc.25) and click Next. Follow the Windows guide and finish entering the requested information. You may then want to print a Test Page once the dialog is completed, you may have to permanently allow requested traffic in the firewall settings again.
Step 11:
Your done, congratulations !
Posted on Jan 10, 2009
    Problem Solver:
  • 7 Answers
Sam,
I'm assuming you have your DSL router setup for DHCP...here is a document that gives specific instructions on how to setup the JetDirect.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpj07358&lc=en&dlc=es&cc=ar&product=75298#N367
Let me know if you need further assistance!
V
Posted on Sep 19, 2008
    New Friend:
Hi Guys...
I'm using HP-Jet Direct J2591A which purchased on year 2005. Can this print server support in Windows Server 2012-64 Bits? I cannot find any resources on this.. Hope anyone can help me in this case.... Thank u...
Posted on Mar 31, 2015
How do I hook up my Westell wireless router to the zhone modem so I can use my laptop. I have to use a dedicated line with a zhone modem to get DSL service. I want to hook up my wireless router Westell...
Connect the Westell wireless to the Zhone as if the Westell is the PC that used to be connected to it. Then connect the PC (through any available port) only to the Westell. That's the WIRED connection. For the wireless to work, after connecting through the WIRED connection, there should be a CD that came with it that will help you configure the wireless.
Feb 18, 2010 | Zhone 6212-I3-200 Router
Switching from a verizon 6100 dsl modem to a 327w versalink
make sure that your old setup not still on go to connect to from the start and right click on the connection and see the one that you are using is present
Nov 08, 2009 | Westell Wirespeed VersaLink...
Westell versalink 327w from bellsouth can't connect
Howdy,
I do not think this modem will work for you. Contact O.T.C. to be sure. For a few details...
I presume that you can access your Westell wireless modem/router 327w with the IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. If you see the Bellsouth FastAccess Internet Service logo then you know you definitely have a Bellsouth modem.
Now, let's presume, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, as stated above, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
This is the page link:
http://www.dslreports.com/faq/bellsouth/3.141_Westell_327W__wireless__Info#13772
This is the relevant quote:
"The BellSouth supplied 327W (model C90-327W30-06) is made exclusively for BellSouth FastAccess. They are functionally different from retail Westells (or any model designed for use with other ISPs) and the firmware between them are not compatible and can not be interchanged."
That being said, you still might attempt to use this 327W with orlando telephone company but I do not know if it will work. (Doubtful...) I use the Bellsouth 327W and it is GREAT. (With Bsouth/ATT) Good luck.
P.S. - Please be advised that Westell does manufacture an identical 327W that does NOT have the Bellsouth/ATT firmware.installed. This is the "generic" version I suppose but I have no experience with this one. If you need more just ask. :)
Good luck,
J
Oct 07, 2009 | Westell Wirespeed VersaLink...
Switching DSL Modems
Your dsl line stays the same. you're only changing your dsl equipment.
if you are not able to go online using the 327w, you might need to have it configured depending on the type of connection that you have. if you are using PPPoE (which means you enter a username and password on the modem to connect to verizon) you need your 327w configured for pppoe. but if you are using DHCP connection, any modem or routers should be plug and play.
Most verizon customers from the west coast uses DHCP while those on the east coast uses PPPoE.
You can call tech support to make sure which type of connection you are using.
Mar 29, 2009 | Westell Wirespeed VersaLink...
Hi I can only use the Westell 327W with DSL
This Westell 327W can only be use with a DSL internet connection since this is a DSL modem..
Hope that helps.........
Sep 19, 2008 | Westell Wirespeed VersaLink...
Westell 327W & Verizon DSL
I have centrytel DSL and westell Model 327W
Sep 09, 2008 | Westell Wirespeed VersaLink...
Westell 327w
Your router is for DSL not cable
Apr 05, 2008 | Westell Wirespeed VersaLink...
Westell router modem hook-up
No. That device is a DSL gateway. It is exclusive for dsl connection.
You can use a Linksys WCG200.
Mar 23, 2008 | Westell Wirespeed VersaLink...
Westell 327w
xbox live connection test MTU failed
Mar 12, 2008 | Microsoft Xbox 360 Console
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
Jan 14, 2008 | Westell Wirespeed VersaLink...
HP JetDirect EX Plus Print Server Logo
15,824 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
