Question about Motorola Mobility Moto Q
Windows Media - no sound
I was trying to watch a show and listen to music and there is no sound. The mute button is not on and I turned up the volume. What should I do next?
  • 3 more comments
  • Anonymous Jul 18, 2008
    ughh! the same thing happened to me just randomly. idk what happened
  • Anonymous Aug 18, 2008
    No sound from the media player...I reset my phone and it was fixed and within 5 days, no sound again.
  • yamadirt Aug 25, 2008
    No sound from the media player or from the ringer.  Need help.
  • Anonymous Nov 30, 2008
    im getting sound only when somebody calls me but thr is no sound in wmp..............
  • Anonymous Apr 21, 2009
    I have exactly the same problem
On the moto q? Just press the wheel button on the side. Earpiece volume will show then roll the volume up!
Posted on Apr 26, 2009
Mine did not shut off but mine the music sometime goes really quiet not when i get fone calls only on the media player the ring tone are still loud but the media player is very quiet
Posted on Aug 16, 2008
Speakers don't mute with headphones on
When you plug headphones into a laptop computer, the laptop speakers are usually cut off automatically. However, if you wish to do this manually, there is a way. One common reason for shutting off the speakers is so that your quiet workplace won't fill up with sound if you should unplug the headset for some reason while playing music or performing some other sound-filled activity.
Muting the Speaker but Not the System On a typical laptop running Windows, left-click on the double chevrons of the "Show hidden icons" button in the Quick Launch toolbar at the bottom-right corner of the screen. This will display all your hidden quick-launch icons, and usually these will an include an icon of a speaker that launches the "Volume Control" utility. If not, then you can also access the Volume Control utility from the Control Panel, via the "Sounds and Audio Devices" application. Simply launch that application, click on the "Volume" tab, and click on the "Advanced" button in the "Device volume" section. In the Volume Control utility, click on the "Advanced" button near the bottom-left area of the window. Near the bottom of the advanced controls window, there will be a section labeled "Other Controls." Here you should see some kind of check-box option labeled something to the effect of "PC Speaker Mute." If you check that box and save your changes, the laptop's speakers will be shut off, but you will still be able to listen to any music or other sounds through your headset. It's as simple as that. To cancel the shutoff, simply uncheck the box and save your changes. This method works for all versions of Windows still widely in use. Hope this helps.
b>
Dec 23, 2012 | LG E500 Express Dual Series Notebook PC
Tip
To connect a music player or other audio device to your laptop
<br />If your laptop has a line-in jack, follow the instructions above for connecting a music player to a desktop computer. But to connect a music player or other audio device to most laptops, you'll have to plug it into a microphone jack. To do so, follow these steps:<br /><br />Click to open Sound. <br /><br />Click the Recording tab, click Microphone, and then click Properties.<br /><br />Click the Listen tab, click the Listen to this device check box, and then click Apply.<br /><br />Click the Levels tab and make sure the Mute button looks like this . If the button looks like this , click it to turn on sound for this connection, and then click Apply.<br /><br />Play some music or other sounds on your device to test the volume coming through your computer speakers. Select the slider under Microphone, drag it right or left to increase or decrease the volume of your audio device, and then click OK. You might also want to adjust the volume on your device.<br /><br />Note<br />If you hear noise coming out of your speakers, try reducing the volume on both the music player and in the Levels tab. The microphone jack is designed to receive sound from a microphone, which is different than sound coming from a music player
on Dec 14, 2010 | Computers & Internet
When i try to listen to music on the internet or play a cd on my laptop the sound doesn't come on. how do i fix this?
There could be many solutions to this problem with out more information it is hard to tell you exactly.. -if this problem just started - check your media player settings and see that it is not muted-with Microsoft windows you will see a small speaker icon in your task bar on the bottom right hand corner of your screen check that it does not have a red x or a muted bar across it also click on it and check that no on e has puled the volume slider down to low volume.If the problem isn't here it could be corupted sound drivers or other related problems
I hope this helps
Andrew
Mar 25, 2011 | Computers & Internet
WINDOW MEDIA PLAYAR NO SOUND
***Codec issue If only some of the movies you're playing do not get sound it's likely you have a codec issue. codec downloads.
***Check volume settings Often no sound in the Microsoft Windows Media Player is corrected by adjusting the volume controls at the bottom of the window. Moving the slider from the left to the right will turn up the volume, if all the way to the left the volume is turned all the way down.
***Make sure not muted In addition to the volume slider, make sure the sound icon is not pressed in. This button is the mute button and will mute the sound.
***Sound Driver Drivers for your sound card download this http://www.devicedoctor.com/device-doctor-download.php
***Update / Reinstall the Windows Media Player
If you continue to experience issues, you may want to consider reinstalling and/or updating the Windows Media player on your computer. You can find the latest Windows Media player on your computer by clicking "here".
Oct 06, 2010 | Computers & Internet
My Sony Vaio VGN-FS690P has stopped playing sound. The sound card states it is working correctly. It does play one sounds, the sound when it starts and show the VAIO screen.
Hopefully this helps. Right click on your volume control icon. Open the "Volume Mixer," and make sure that nothing has the mute X on. Then right click on "Volume Control," and make sure that the volume control is checked to play all sounds, and that your Speaker box is checked. Next step is your music, if the sound was muted directly @ the music playback, this could be the problem. Open your Media Player and try to play music, if you cannot hear it, click on the mute button to the song playing. If your Player was shut off in the "mute" mode, then you will not hear sound. It Happened to me once. You will need to check all of your "Players" to see if any of them were shut off in "mute."
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Sep 26, 2010 | Sony VAIO VGN-FS690P Notebook
No sound when computer is being shut down or playing music on windows media player. button next to power button not lite up. push mute button back off still cannot get a sound.
Check the volume controls and sound properties. Make sure that the master volume ins not in "MUTE".
Double-click the speaker icon on your tool bar. The volume controls will appear.
Check the Sound properties:
Right-click the speaker icon > Adjust Audio Properties:
Audio tab > make sure to select the right sound device.
Thank you and good luck!
Sep 12, 2010 | Dell Latitude D600 Notebook
The volume on MP3 play goes to mute during listening and can't get it back up. I turn the dial and the volume level doesn't show
try reflashing the firmware for your device you can find the latest firmware and flashing utilitys from the manufacturers website.
Make sure taht you back your music up first because when you do this you are setting it back to factory settings.
Sep 29, 2009 | RCA Lyra RD2765 MP3 Player
No volume or sound for my Laptop
Please check to see if your sound card is installed/enabled, then check to see if the sound files are set to open with that device. Your computer should already have a media player installed (if you're using Windows). Set your music files to open with the media player.
Feb 26, 2009 | Acer Aspire 5500 5570-2609 Laptop
Philips GoGear will not repair
Uninstall your Windows Media Player 11, and rollback to Windows Media Player 10 first. instructions at microsoft.com or www.usasupport.philips.com.
Then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mps Doctor
May 30, 2008 | Philips GoGear HDD1830 MP3 Player
Inbuilt Speaker not working
Dear Biswaranjan.
the volume control on media player before that there is one button for speaker click on it and sound will come from media player. I think you have muted on media player.
Feb 26, 2008 | Computers & Internet
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier&#39;s store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn&#39;t seem to recognize it right now - I&#39;ve seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola&#39;s site for your carrier. I just downloaded the Verizon firmware as an example - Motorola&#39;s website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
248 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
