Question about Compaq Floppy Disk Drive - 344897-001 CD-ROM Drive
Have no fdisk can lode anything
Wrong ms-dos it use to work
  • 101 Answers
I am not getting your point not rong ms-dos its command promt you can do the work through this
Posted on Jul 07, 2008
It's impossible install MBR, How I can get install?
If this MBR mean, Master Boot Record, it's a DOS-alike thing.
You require a DOS or Windows 95 / 98 bootflop, containing the program FDISK (forgot if it was .com or .exe)
After booting you get the DOS-prompt which is text-based and looks like :
"A:>_" or "C:>_"
Now, in this case you enter the following: "fdisk /mbr"
So the DOS-prompt will look like :
"A:>fdisk /mbr" or "C:>fdisk /mbr"
Then you hit the ENTER-button at your keyboard and if DOS can find this fdisk-program, it will rewrite the master boot record of your harddisk.
Oct 11, 2013 | Toshiba Computers & Internet
Tip
Creating a bootable flash drive
<p><b>Resolution:</b><br /> <p>The USB Flash Drive must be configured with an active primary MS-DOS partition. It must also contain the boot files. Follow the steps below to create a bootable USB Flash Drive. <br /> <p><b>Requirements:</b><br /> <ul> <li> Motherboard with BIOS that supports USB boot. <li> USB Flash Drive that may be erased. <li> Bootable floppy disk or CD with Fdisk and Format commands. </li></ul> <p><b>Directions:</b><br /> <ol> <li> Plug in the USB Flash Drive. <li> Make the USB drive the only bootable hard drive. <b>Method 1:</b><br />If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. <b> Method 2:</b><br /> Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. <b> Method 3:</b><br /> Unplug all hard drive cables inside the case. If the cables are unplugged the computer cannot detect and boot to the hard drive. <li> Insert the bootable floppy disk or CD into the appropriate drive. <li> Restart the computer to the bootable floppy disk or CD. <li> At the command prompt, type: FDisk. <li> Delete and create a new active primary DOS partition. <li> Use FDisk to delete all partitions from the USB Flash Drive. <ul> <li> In FDisk, press the 3 key to Delete partition or Logical DOS Drive. <li> If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition. <li> After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER. <li> A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER. <li> You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER. <li> The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu. </li></ul> <li> Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2. <ul> <li> In FDisk, press 1 to Create DOS partition or Logical DOS drive. <li> Press 1 to Create a Primary DOS Partition. <li> The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER. <li> The next screen prompts that the computer will now reboot. Press ENTER to continue. </li></ul> <li> Exit FDisk and restart the computer. <li> Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected. <li> At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER. <li> At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER. <li> Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\&gt; command prompt. <li> Change the settings made in step 2 back so that the computer operates normally again. </li></ol>
on Mar 14, 2011 | Computers & Internet
Tip
Creating Bootable USB Flash Drive.
Requirements:
  • Motherboard with BIOS that supports USB boot.
  • USB Flash Drive that may be erased.
  • Bootable floppy disk or CD with Fdisk and Format commands.
Directions:
  1. Plug in the USB Flash Drive.
  2. Make the USB drive the only bootable hard drive. Method 1:
    If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. Method 2:
    Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. Method 3:
  3. Insert the bootable floppy disk or CD into the appropriate drive.
  4. Restart the computer to the bootable floppy disk or CD.
  5. At the command prompt, type: FDisk.
  6. Delete and create a new active primary DOS partition.
  7. Use FDisk to delete all partitions from the USB Flash Drive.
    • In FDisk, press the 3 key to Delete partition or Logical DOS Drive.
    • If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition.
    • After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER.
    • A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER.
    • You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER.
    • The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu.
  8. Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2.
    • In FDisk, press 1 to Create DOS partition or Logical DOS drive.
    • Press 1 to Create a Primary DOS Partition.
    • The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER.
    • The next screen prompts that the computer will now reboot. Press ENTER to continue.
  9. Exit FDisk and restart the computer.
  10. Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected.
  11. At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER.
  12. At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER.
  13. Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\> command prompt.
  14. Change the settings made in step 2 back so that the computer operates normally again.
on Mar 31, 2010 | Computers & Internet
Partition table error 105 found
#105 Partition starts on wrong boundary
You may need to use the FDISK program from a recent DOS version because earlier versions may refuse to delete HPFS or hidden partitions, and the OS/2 FDISK program may recognize the partition's corruption and refuse to modify it.
In some cases, you can resolve partition table errors manually.
Jun 06, 2011 | Symantec Partition Magic 8.0 (PM80ENK1)...
I installed just as the instructions said and i cant get my pc to recognize my 1.5tb hard drive
First download this disk iso and add fdisk to the disk and burn ituse this link:
http://www.bootdisks.us/ms-dos/5/ms-dos-bootable-cd-images.html
download fdisk from this link FDisk 6.22
http://www.uv.tietgen.dk/staff/mlha/Download/dos/#FDISK
Once you have downloaded and burnt the disk, make sure the drive is showing in the bios, then set to boot using the cd/dvd-rom and insert the disk.
When loaded, at the command prompt type fdisk, find the 1.5tb hardrive and create a primary dos partition, it may take a while so be patient, once done take the cd-rom out of the drive and reboot the mechine, goto my computer and you should see the drive, and it will have a drive letter next to i. It want contain anything as it has not yet been formatted.
To format just right click on the drive and choose format, choose ntfs and press ok, it takes a while so again be patient, and you should now have a usable new drive. hope this helps, any problems post back.
Apr 06, 2010 | Koutech Systems IO FLEX-PSA150...
Won't boot from anything. Tried safe mode, bootable c.
hi,
the fdisk option can only be run from DOS so you need to boot off a floppy disk or a bootable CD containing diagnostic software. Perform the fdisk the check partitions and then a scandisk to check for cluster/sector corruption
Jul 14, 2009 | Computers & Internet
I formated my c drive of my acer aspire 1640z, and when i try to restore with my restore cd i get the mesage boot manager is missing.can you help me pls?
Your restore disks also use fdisk and format to do the same thing you did this way by reformatting, but without all these extra hassles. Do you have a primary partition that is in active status? to check use a Windows boot disk or an MS Dos boot disk making sure that they have fdisk.exe,format.com,sys.com,and scandisk.exe
1.run fdisk and select option 4(display partition information)
2.if the partitions are listed then look for an uppercase A in the status column of your primary partition
3.if there are no partitions listed use fdisk to create new partitions and then use format to format the partitions.
4. then try your restore disks they should work, if you have already done all of this email me thescaleofanubis@yahoo.com and we will move on from there if you are still having the problems. Hoped it helped!!!
Mar 13, 2009 | Acer Aspire 1640Z Notebook
I`m unable to install windows 98 in seagate 80 gb ide barracuda hdd
For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
FDISK LIMITATION WITH 64GB DRIVES:
Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
Direct English Version download:
http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
Dec 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Missing G drive
well go to the device manager and check for the devices enlisted there and update your dvd/cd device from it properties>update drivers and update it from the internet!!in ms dos mode run fdisk and check ur partition be sure you are good at working with ms dos oderwise you will end up messing things
Jan 31, 2008 | Compaq Presario V4000 Notebook
Computers & Internet Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
