Question about GE Spacemaker JVM1640SJ Microwave Oven
Cuts off after 2 seconds
The subject pretty much says it all. We turn on the cook time, hit start and within seconds it shuts off, blinks out and have to put the date/time in again.
  • jbell44 Apr 06, 2009
    I have the same problem. Have had the microwave for about 3 years, plugged into the same outlet.
  • GE Master
  • 5,568 Answers
Just a hunch; plug it in to a different outlet.
AC outlets are only marginal when new and that unit can draw well over 10 amps.
If the contacts are failing, the unit will think it has been disconnected, killing off the clock setting too.
If that doesn't help, try plugging another high power appliance, an iron, toaster or coffee maker, into the same outlet used for the GE to see if they behave normally.
Posted on Jul 07, 2008
Convection oven shuts off after a minute when trying to bake. Does this during Compubake also.. Does not preheat
Possibly a bad oven temp sensor. If the uinit doesnt read a temperature it will shut down to prevent a fire or over heating. The temp sensor is a thermister A temperature variable resistor that changes value as the temp changes. so If the main board doesnt get a response within a vertain resistance range it shuts things down. Sometimes since those parts are in the actual cooking area and subject to the heat and steam from cooking they can rust and break, or just get old and break. Or slam the door and break, you get the idea!!
Oct 19, 2017 | Sharp R-1874 Convection/Microwave Oven
Sometimes oven does not work. when ya hit start it just clicks - the screen looks normal for about 2seconds & then shows the clock time.
Sounds like is what's happening:
Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back.
That would be a bad upper interlock switch and charred connector. If so, see:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Dec 11, 2012 | Panasonic NNSN797S Microwave Oven
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
I have a Panasonic microwave convection that runs for 2 or 3 seconds, then cuts off. It doesn't matter what setting or length of time you program into it, it will run a couple of seconds and shut down. Is...
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Sep 08, 2010 | Panasonic NN-C994S Convection/Microwave...
Model JVM1650WH02 will shut off about 2 seconds or less into cook time. everything else works such as light and clock and sometimes the wave will cook.
magnetron is leaking internally, do not use until magnetron is replaced. the mag creates interference with the control board and resets it
Feb 05, 2010 | GE JVM1650 1000 Watts Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
Sanyo Em-u1000w
i have the same microwave and mine does the same thing,try this push the clock button and enter the time or just push 100 and hit the clock button and then enter in your cook time and hit start.
Jan 10, 2008 | Sanyo EM-U1000W Microwave Oven
Timer problem
Sounds like your timer board is fried. Replace it.
Dec 19, 2007 | Panasonic NN-T774SF Microwave Oven
New microwave not starting
Chances are the oven is designed for 60HZ and your supply is 50Hz. This will cause the unit to shut down because it thinks it is not getting the proper "interrupt" signal from the power line. You can check the owner's manual (or model number tag) and the manual for the converter.
Apr 20, 2007 | GE JES738 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
147 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
