Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool sidebyside The water line to my side by side has been cut and I need to get up inside the door to fix the hose, how do i do this?
  • 481 Answers
  • take off the door,
  • remove the inside panel (screws under door seal)
  • dig out insulation until you reach water line
  • install a repair union
  • fill up the empty space with spray foam insulation
  • reassemble when the insulation dries.
Posted on Jul 06, 2008
My water hose line is broken inside of the whirlpool side by side fridge, how can I get inside door?
In most side by side fridges the water tube goes up through the bottom of the hinge on the ice dispenser door.Where is the tube broken?
Aug 07, 2011 | Whirlpool Refrigerators
RE: whirlpool refrigerator side by side ED25RFXFW01. I accidentally severed the water line inside the freezer door. How do I get to it? It appears that the shelves and insulation are glued to the door,...
The water line can be replaced by removing the dispenser cover and disconnecting the tubing and then pull the old line down from the bottom hinge area. once out, you can install your new line back up into the place it came out of. it goes through a channel inside the door. once back up in dispenser area..connect back to nozzle. the hose under freezer door needs to be connected as well...
Feb 03, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking from bottom of fridge. Hissing noises coming from inside. Trying to figure out how to disconnect water
There is usually a water cut off , behind the refrig , mounted on the wall , or , a cut off under the sink , connected to the cold water line ( with a small cut off valve ) .
The hissing noise , is usually associated with a hole or cracked water line . You can also try removing the ware filter , to see if the noise stops .
Would need more info , to have an idea where the water line is defective .
Nov 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking
there should be a quick disconnect about 4 inches from the bottom of the door. look behind the toe kick. if it leaks from the disconnect try pushing the plastic lines into the disconnect. the disconnect is about 1.5 inches long and should have red or blue ends. to get the lines out you push the colored ends in while pulling the plastic line out, try cutting off the ends smooth and straight up and down and re-insert. if the water is coming out of the bottom of the door you need to replace the water line in the door.
to get the line out of the door. use a flat blade screwdriver to pry the dispenser cover off the door. there are two slots on the bottom of the dispenser facia. use a pen or something hard for a pivot point and use tape to protect door finish. push on the screwdriver until you think the plastic will break, then push a bit harder and it will pop off. now you can disconnect the facia and remove the screws holding the switches etc. disconnect the water line and pull it through the dispenser. to put the facia back on just hook the top and line it up and press the bottom back on.
May 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool sidebyside FF stopped working after ? motor stopped ...
this refrigertor is leaking refridgent gas it needs checked by an engineer
Feb 15, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Whirlpool Side by Side Water line cut at door hinge on bottom
you can try to take the inside of the refrigeerator door off and then replace the line or just quit using the feature. i would take the door off and take the inner panel off and replace.
Jan 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
HOW TO GET TO THE WATER HOSE INSIDE DOOR. ED5FHGXXKQOO
what brand is it give the model number and brand if is a frigidaire sorry but no there is no fix the hose is insulated inside door
Oct 16, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice maker not getting water
PULL THE TUBE BEHIND THE ICEMAKER OUT AND SEE INSIDE IF IT IS FROZEN,IF NOT ALL THAT'S WRONG IS THE WATER INLET VALVE ON LOWER BACK OF FRIG.IS BAD,YOU HAVE A WATER DISPENSER HOSE ON ONE SIDE AND A ICEMAKER HOSE ON THE OTHER,THE ICE MAKER SIDE OF THE VALVE IS BAD,THANKS-MIKE
May 29, 2008 | Whirlpool GS5SHGXLS Side by Side...
Samsungrs21dcns water dispenser problem
just below the doors of the frig is a kick plate. remove the kick plate. on the left youll see a water line that goes into the freezer door. there is a connection for that hose just under the freezer. disconect the hose the press the water dispenser. if water comes out of the hose then the water line is frozen inside the door. you can use a hair dryer to warm up the dispener area both from the front and from the back, inside the freezer, it will take about 30 min to defrost. but, if you get no water from that hose then you need a new water valve. more than likely its frozen in the door. thats common on ge models
Nov 26, 2007 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
83 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
