Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Beeping Ice Machine
The problem with the ice machine is that it's beeping and not making ice...and the metal bar over the ice bin is in the proper position.
  • 1 more comment
  • Anonymous Aug 11, 2008
    i have a similar problem ice machine beeping and isnt making ice
  • DaveGillie Nov 29, 2008
    My Hoshizaki KM-900MWH beeps ONCE every 5 to 10 seconds. repeatedly.
  • pyo8873 Jan 14, 2009
    my machine is KML-631-MAH hoshizaki. Im buy justtwo weeks.
    three time beeping and ice is smaller size every 15 min comeing down.
    this machine set up 35min. why 15min .
    can you advice how to change a set up time????????????
    please call me or e-mail.
    tel 684-770-1017.or 684 -699-6553.
    e-mail ; pyo8873@empal.com
    contac Mr PYO
  • 770 Answers
The beeping is a fault code i need to know how many beeps it does before it starts over Also you can shut down the pwr this will reset it but if you dont fix the fault it will return
Posted on Jul 08, 2008
2 Suggested Answers
SOURCE: Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Posted on Aug 29, 2008
My hoshizaki ice machine KM-900mrf model beeps 3 times and stop making ice. After reset it starts, but stats beeping again after an hour.
Have a look at the side of the evaporator; there is a probe (thermistor) attached to it that tells the control board when to initiate the harvest cycle. make sure it's clean and attached properly and doesn't need replacing. If hitting the float switch initiates the harvest cycle it sounds like you have a blocked/ scaled water tube or switch housing. take off the bottom of the switch assembly (black rubber bit) and clean through to the water chamber. run a cycle of descaler before trying again.
Jul 04, 2015 | Hoshizaki Freezer Commercial Ice Machines...
Why isn't my Hoshizaki km 630 mkh ice maker not making any ice?
that could be a number of problems..is it making any beeps or flashing lights on the circuit board? Have you tried to reset the circuit boards reset button with the machine on. ? If the machine seems totally dead then the bin thermostat is most likely the problem..
Aug 02, 2014 | Hoshizaki Freezer Commercial Ice Machines...
How to reset hoshizaki ice machine
small white button on control board. press once to stop beeping. Very small but it is labeled and very hard to see.
Feb 09, 2012 | Hoshizaki Freezer Commercial Ice Machines...
My machine doesn't makt any ice and the macine is beeping.
Need to know the number of beeps as this is a code to tell you what went wrong with the machine.
Aug 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
My Ice machine started beeping from the fuse last night and is not working
The beeping in ice machine is a code. Take off the electrical panel cover. Carefully look for and press the small reset button on the board. This will restart the machine. If it shuts off again call a service company out.
Oct 18, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Beeping 3 times every 3 seconds
The 3 beeps indicates that the unit was in the freeze cycle for 60 minutes. Causes: 1.) Water valve leaking, allowing water to continually enter the system. 2.) Float switch stuck, sending false signal to board. This indicates ice not being produced. 3,.) Low freon level causing long freeze cycle. 4.) Hot gas valve leaking thru causing warmer than normal evap plates=low production. 5.) Expansion Valve not feeding freon properly to evap plates.
Items 1 and 2 are the most common. Number 3 possible due to freon leak in the system. Number 4 and 5 are usually a very rare occurance.
Hope this helps ya.
Sep 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine model KM-250BAF SERVICE MANUAL
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
Jul 30, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Beeping Ice Machine
Jul 09, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine with constant beeping every 3 seconds
Most likely(50% of the times) Your Ice machine need a real cleaning. not just run clean cycle with ice machine cleaner. every 6 month call HVAC-R guys - machine will last half time longer if u schedule proper maintenance with them. I have seen It all: people try to call "friend", or someone who "knows" how this machines work. Real clean would take up to 3 hours for people who know what they doing. Here is one of my videos, when 3 beeps - long freeze cycle is not common and all others would offer You to get a new Ice Machine. Bill to the owner was 950$, New Machine 3450$ plus labour to install 600$.
Jun 23, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Ice machine
3 beeps. hoshizaki replacing txv
Dec 21, 2007 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
567 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
