Question about Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-S8 Projector Inoperative
When the ON/STANDBY button on the TDP-S8 is pressed, the green light cycles from on to off, then back to on; usually nothing else happens. Occasionally, the lamp inside comes on for about 2 seconds, then goes out. The device does nothing else. Resetting the power does not help. I have never received the message indicating we are approaching the lifetime hours of the bulb. Any idea what's wrong?
Dan
  • 5 more comments
  • malliksl Jul 13, 2008
    I have same problem.
  • niallmartin Jul 20, 2008
  • kpunx Jul 20, 2008
    Same Problem
  • tommysproaud Jul 26, 2008
    owersa up then shuts down not sure if it can be reset thank you i have the same thing going on that the other user is
  • Anonymous Sep 01, 2008
    Same problem, but I could not see a solution on this web page?
  • behsstlc Sep 01, 2008
    Same problem, but I can't see the solution on the web page.
  • Nick Kaye
    Nick Kaye Sep 02, 2008
    Have the same problem. Wants to start, and bulb lights up, then quits before picture. Need solution if someone already got it!
I have the same projector with the same problem, and after looking on other forums, the solution is that the 3300uF 10v electrolytic capacitor swells and needs to be replaced. Take the projector apart by removing the screw located on the bottom and everything will snap apart. You need a soldiering iron to do this, but only takes a few hours. The part can be found for about $1 + S/H. You can replace the capacitor with one between 2200uF ~ 4000uF /10v-16v.
Posted on Jan 26, 2010
    Problem Solver:
  • 6 Answers
The main board has 2 caps near the rear audio input that get pushed off the board buy the balist power supply they are smt type if you can get them to reconnect by reheating with low heat iron you can then glue them to prevent this from happening again.
To deturmine if this it what is the problem pull the cover from over the
color wheel if it doesn't turn when hitting power these caps are in the motor control so that will fix it if you get the caps back in the curcuit!!!
Posted on Sep 15, 2009
Thank you it worked
Posted on Jul 17, 2008
  • 52 Answers
I have the same projector, and had the SAME problem.
After unplugging and taking on a trip it didn't work...it just lit up for 2 secs, and then shut off....
LEAVE it plugged in for as long as it takes for the light to stop blinking, and then it should start up on its own, or if you press the on/standby buton.
Be patient, hope this works for you too!
Posted on Sep 03, 2008
My projector lamp turn on about 2 then turn off. light bulb haves
the power supply needs to be replaced. if you're good at soldering, there is a capacitor that dries up quickly on the ps board. i believe it's c2.
Nov 09, 2009 | Toshiba TDP-S8 Multimedia Projector
It shows no signal
Toshiba TDP-S8 projector cannot communicate from my laptop, it shows no signal. how can i fix it? thank you so much...
Feb 19, 2009 | Toshiba TDP-S8 Multimedia Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Toshiba Projector won't turn on!!!
I had the same. Try to press the "input" and "menue" buttons and plug in the power cable. No control light should be active after that. Press the "power" button and it should work.
Dec 19, 2008 | Toshiba TDP-S8 Multimedia Projector
Same problem as below.
Sep 01, 2008 | Toshiba TDP-S8 Multimedia Projector
Aug 23, 2008 | Toshiba TDP-S8 Multimedia Projector
Projecter not working
I have this same problem with no indication of what is wrong with the projector. I have checked the bulb and see no lines (veins) or bubbles on it.
Jul 20, 2008 | Toshiba TDP-S8 Multimedia Projector
Standby light for toshiba
probably power supply or ballast (starts the lamp)
either would be $600.00 or so to repair, probably costs more than the projector is worth.
Jul 15, 2008 | Toshiba TDP-S8 Multimedia Projector
Does not detect input source
Hi Figburg
Press the Fn ( function button ) and while holding it down , press the button in your F-row with the 1 or 2 screens on it.
Should do the trick.
May 03, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-S8 Multimedia Projector Logo
996 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
