Question about Samsung HCN4727W 47" Rear Projection Television
Picture Bowed In On Both sides
Samsung W/S Model # HCN4727W5S Picture is bowed inward equally on both sides.Convergence is perfect. Noticeable on all picture sizes but mostly on :4:3 Changed Convergence board but problem remains. Thanks Earl
  • 6 more comments
  • earl mccain Jul 06, 2008
    No solution was offered.Please repost
    This cure to this problem "is not" an adjustment.The picture & convergence is perfect.There is no adjustment that can adjust bows on both side of the screen. The cure is going to be a bad part,what part is defective?
    Once again,this problem is not an adjustment,
    a person would have had to have this problem before & remember what part cured the problem.
  • earl mccain Jul 07, 2008
    Thanks,but just suggesting a cap is out in the horz. is really no help.Help would be the location and cap value .The horz. circuit is much to large to just suggest "a cap is bad" Thanks ,your at least on the right track.
    If anyone has a manuel or know "which cap" is bad (probably in pincushion circuit) please respond to the problem listed for this W/S Samsung TV thats Bowed in on both sides, Thanks , rioconcho
    If anyone has a service manuel and knows the defective part and location # then they can actually help.
    Having a service manuel does not tell a person what part is defective,"only a person whom has had this problem & was able to repair it" can effectivly answer this problem. Telling a person they need a "new several hundred dollar new board" is really rediculous ,the problem will be a part that sells for less then $3.00 .If you don't know the part thats bad don't reply.
  • earl mccain Jul 09, 2008
    Thanks for all the sugestions.So far none have cured the problem so if anyone has any new things to try please respond.
    Sergeant:
    Champion:
  • 417 Answers
Ok here we go if you have any speakers close to the tv remove them away at lease haft meter Then turn tv of 4 30 to 40 minutes then turn back on make sure you turn the tv of by the power point or it will not work there has to be no powergoing threw it
Posted on Jul 09, 2008
  • nicholas Rokkasarno
    nicholas Rokkasarno Jul 09, 2008
    ok here we go if you have any speakers close to the tv remove them away
    at lease haft meter AWAY FROM THE TV Then turn tv of 4 30 to 40 minutes then turn back
  • Samsung Master
  • 19,396 Answers
Convergence ICs are STK392-120, one of them is faulty. You need to test the pico fuse at the base of the convergence ICs and replace the IC.
After replacing the IC perform service convergence adjustment shown.
Posted on Jul 07, 2008
    Genius:
  • 1,226 Answers
Most of the cases, this kind of problem fault in the horizontal and vertical projection of the TV. If you can self tech the TV you have to check the REgulator and the capacitor in the circuitry mainly in the ver and hor board. however some cases can be resolve by some sort of adjustment inside the the TV which allowing to tweak the adjustment therein if it is not auto adjustment.
On the otherhand, if you change the convergence board guess it was mis-match in the system and not correct the power output regulated by that board.
reminders:
some replace may not fit, So use or replace the original replacement reccomended by the manufacturer.
melnavz
  • 105 Answers
Tr to restore the tv to the default mode.or visit the www.samsung .com or try toadjust it yourself using the adjustment settings
    Genius:
  • 2,035 Answers
I would recommend going to the following link and getting the service manual so you can see first hand disassembly instructions and testing procedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new KD board. heres the link.
http://servicemanuals.vstore.ca/
  • 2,071 Answers
Bowed or bent pictures is caused by defected leaky or short,correcting voltage electrolytic capacitor in AGC section,and faulty first I-F or AGC gate transistor,change this defected parts electrolytic capacitor and transistor,so picture will better again..
  • 4,234 Answers
This is a problem with the pincushion circuit. Usually this gets traced to a capacitor in the circuit. I don't have themanual for this model. If you look at the PC board, the circuits may be labeled. If so, look for a small capacitor in the 10 microfarad range in that circuit. It will be defective.
Dan
  • 790 Answers
Hi
this is horizontal section problem!!! some capacitor need to replace! and neeed to torubleshoot...
Posted on Jul 06, 2008
  • 1 more comment
  • carlos fernandez Jr.
    carlos fernandez Jr. Jul 06, 2008
    can you post a picture of you unit to see what exactly the problem of your unit!
    Thanks!!!
    Thanks!!!
    carlos fernandez Jr. Jul 07, 2008
    the value of capacitor is around 100 to 150 microfarad 300 to 400 volts.
    President:
  • 1,257 Answers
Try resetting it to its factory setting through remote control.
Hope it works.
    Genius:
  • 1,665 Answers
Doe following procedure work?
1. TV turned off
2. Press 'Mute' then '182' then 'Power' buttons on the remote.
You are now in the Adjustment mode
4. Use the 'Channel up'or"Channel dwn' to select the category.
5. Use the 'Volume up or dwn' to enter the category.
note:Some models may not have Category Selection.
6. Use the 'Channel up or dwn' buttons to select item to be adjusted.
7. Write down the old value of the item before changing.
8. Use Volume up and down adjust the value.
9. When you have made all the adjustments you want turn the set off to exit.
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Jul 07, 2008
    157 page service manual for Samsung projection color TV receiver, model #'s HCN4226WX/XAA, HCN4226W3S/XAA, ST54T8PCS/XAX & HCN4727W5S/XAA. Chassis # P55A(N) REV.1
    157 page service manual for Samsung projection color TV receiver, model #'s HCN4226WX/XAA, HCN4226W3S/XAA, ST54T8PCS/XAX & HCN4727W5S/XAA. Chassis # P55A(N) REV.1 ~>USE THIS SET!!<~
    http://www.eserviceinfo.com/index.php?wh...
    Download service manuals in .rar format. To expand you need winrar 3.71
    Sergeant:
  • 275 Answers
Go to www.samsung.com for technical support
My screen to my RCA 56" HD TV is messed up. The picture seems to be bowed inward and the colors are all mixed up. I tried to do the convergence but it is not on the menu and I remember it being there...
t is the problem of convergence setting or convergence IC.
Comment by ready2helpu, posted on Oct 21, 2008 IF THE PROBLEM OF CONVERGENCE SETTINGS then check out this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
if the problem of convergence IC THEN check out this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
you can do it manually.
thanks.
Oct 21, 2008 | RCA R52WM24 52" HDTV Projection Television
Picture is bowed at the top and bottom of the screen. The "Perfect Focus" option does not work to fix this. Is there a way to manualy adjust the picture
If the perfect focus isnt working its caused by failed convergence. You can get the convergence board from www.tvrepairworld.com its under the Samsung / Akai circuit boards.
Mar 30, 2011 | Akai PT5598HD 55" Rear Projection...
Borders bowed inward,blurred red,blue, & green
the next time it is not working go into the customer menu with remote and call up the convergence grid and look---there---if convergence is way off and or comes and goes---this set uses 2 Stk-392-570 ic's and it is quite common to see them become intermittant.
Aug 03, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Screen is bowed on top and bottom.
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 13, 2009 | Samsung PCL5415R TV
Distorted Screen for RCA HD56w66
convergence is the problem. first question do you have convergence in the customer setup menu. if you do not it could be a special small fuse if you do have "convergence" in the setup menu then you most likely have a convergence power board issue. and generally they are replaced. in our shop such board replacement average 124 labor and about 100 for part. if the fuse bout 15 for part and 80 for labor. there are solder connection that cause the blown fuse
Feb 20, 2008 | RCA HD56W66 56" HDTV
RCA D52W20 52" TV AUTO CONVERGENCE WON'T COMPLETE
Sounds like your convergence chip has gone bad. Usually costs about $300-$400 to fix. I would call a local TV repair shop and let them give you a free estimate.
Jan 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergence
Im trying to install that same board on the same tv how did you do it?
Apr 06, 2007 | Samsung HCL4715W 47" Rear Projection...
Picture bowed on sides
how badly is it bowed on both sides? if it is too much. ther is a fuse resistor that is gone bad near the coil in the east west section. you need to replace that. if it is not too much..you need to get into the service mode to fix that..good luck
Apr 05, 2007 | Samsung PCK520R TV
Samsung HCN4727W 47" Rear Projection Television Logo
74 people viewed this question
Henry  Thomas
Henry Thomas
