I have a Trane XL900 thermostat that has s frozen screen. It doesn't function and won't let you change any settings.
2 Suggested Answers
  • 82 Answers
SOURCE: my trane xt300 themostat is stuck on wake mode. Cannot
Press run prgm. If unit stays in Wake Mode the thermostat must be replaced.
Posted on Mar 31, 2010
My nook color has frozen screen and won't shut completely down
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site BNTPrice.com that sells them for cheap. i hope this works for you
  1. Press the "n" button to display the quick nav bar.
  2. In the quick nav bar, tap the Settings icon.
  3. In the Device Settings section, tap Device Info.
  4. Tap Erase & Deregister Device.
  5. Stop. Think. Think again.
  6. If you really, really want to do this, go to Step 7. If not, tap the Back button.
  7. Tap the Erase & Deregister Device button.
May 24, 2012 | Barnes & Noble Nook Tablet
Maytag Refrigerator MFF2557HES - won't stop running, everything frozen... despite adjustment to temp setting What to do, please and thank you?
Possible that the thermostat or the control unit is faulty as it fails to cut off the compressor.In some cases the frost or ice formation can reduce the connection or wire contact of the thermostat and so the function will not work. You need to remove the freezer rear covers to confirm if the wires are intact and also if the thermostat is working along with the auto defrost timer.
Sep 19, 2011 | Maytag MFF2557HES Stainless Steel French...
My packard bell won't load windows. When i turn it on the packard bell logo appears and then a black screen with American Megatrends appears with which Function keys to press and at the bottom of the...
try to change your cmos battery,and first boot your hardrive,and set your time and date properly then save your settings take a look if your settings will be save.if yes,that means your cmos battery is the isue.
Sep 14, 2011 | Computers & Internet
It's "frozen". won't change from the screen its
Try to reset it by taking out the batteries and leaving to sit for a minute or so, if that doesn't work take out the small battery as well and leave it sit, if you're still stuck you can call ti-cares (800-842-2737) they're generally very helpful.
Aug 05, 2011 | Texas Instruments TI89 Titanium Scientific...
I have a Trane XL900 Deluxe programmable thermostat. I has worked fine since we purchased our new home April 2011. All the sudden we have a problem with it holding the right settings at night. I have...
Try it with out the programming. There is no fix if the dates and times are correct. Before you call someone you are better off buying one online ($150) and changing yourself. Should not even have to do any wiring, just remove screen and put new one on old backplate. Of course you will have to redo all your run times with the new one. Likely pay that much for the service call just to hear you need a new one. Good luck.
Mar 11, 2017 | Heating & Cooling
My Trane thermostat (TCONT600AF11MAA) is supposed to have 1.5 degrees of heat pump "rest" above the desired setting before turning on the heat pump. The thermometer reading does not change yet...
Friend! All thermostat is calibrated to cut in and cut off at the end of - or + 1 degree end.
Example: If you set 23 degree, it will cut off in 21 degree and cut in @25 degree. So accordingly you set the temp.
Secondly, don't set temp near to your room temp.Minimum difference should be 3 degree. If your room temp 12 degree, set at least 15 degree for heat and if room temp 28, set at least 25 degree for cool.
Hope it's helpful?
Jan 02, 2011 | Heating & Cooling
My trane xt300 themostat is stuck on wake mode. Cannot
Mar 31, 2010 | Heating & Cooling
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
1994 trane furnace fan will not shut off xl 1200
Hello there:
please contact a certified trane dealer i think that you are having a thermostat problem they may be able to assist you on setting the thermostat the correct way . ok?
best regards
mike
Aug 15, 2009 | Heating & Cooling
Heating & Cooling Logo
234 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
