Question about Mitsubishi WD52527 52" Projection HDTV
Help to repair a TV Mitsubishi WD-52527..
The Tv doesn't turn on. This is what hapen every time i plugged it: the timer led start flash rapidly for a short while then shuts off. After about 30 seconds, it will repeat one more time; after that i press the power button but nothing happens. The TV doesn't turn ON! I tried to reset the unit but no luck. Can you help me? I wil apreciate any advice. Thank You.
  • pancholin72 Jul 06, 2008
    I checked the reset button and it was depressed.
    Sergeant:
  • 275 Answers
  • Gandhi Khwairakpam
    Gandhi Khwairakpam Jul 06, 2008
    repair your tv by taking it to a repairing center.
    Genius:
  • 1,665 Answers
Power supply must be checked by an authorized service station
Posted on Jul 06, 2008
  • 6,487 Answers
Looks like a repair is in order.
Do a TV reset (confirm at least physically that the reset button was depressed).
Power down, unplug.
Let it sit, turn on later.
If nothing, good luck with the repair so better take it to a repair center and have it check and let a professional do it for you....
Hope that helps.....
WD-65734 Mitsubishi TV won't turn on. System reset
Are there any lights lit on the front of the TV? Have you checked for a bad lamp? When you reset the TV the timer/power light should flash on and off rapidly for 60-70 sseconds. Does that happen?
Aug 26, 2011 | Mitsubishi WD-62526 Projection TV
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
I have a mitsubishi WD-52527 TV with error code 45
You have to pull the light engine to get to the pbs fan it is the one located closest to the lense on the light engine. you should be able to see if the fan is turning without removing the engine.
Sep 06, 2009 | Televison & Video
No frikin' sound!
Either way the first thing to do if you haven't already is to pull the plug and wait a minute and plug it back in. This will cause the TV to do a hard reset much like re-booting a computer. You can also accomplish this by pressing the reset button on the front panel on some models. If you still have no sound confirm you're getting it from the source. Check for sound with alternate sources like a DVD player or video game.
michtech
Feb 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD52527 52" Projection HDTV Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
