Question about Kenmore 12502 Top Load Washer
Hooking up a used washer
There seem to be too many hookups on the back of the washer--Kenmore 70 Series. Sure we can hook up the hot and cold water and the drain hose, but what are the other holes for?
  • preciousbina Jul 06, 2008
    We found a diagram on the Sears website that says how to hook it up. There are two drains, that much I know. My hubby has the diagram and parts list and understands how to do it, I hope. :)
  • 481 Answers
There should not be anything else. can you send a picture, because someone may have rigged it somehow.Hooking up a used washer - a077143.jpg
Posted on Jul 06, 2008
Series 60 cold water runs slow
turn off water to washer remove cold water hose at washer. there should be a screen in the valve that needs cleaned. should pull out with a small screwdriver or pliers. wash out and re install. you may deform it removing it but it will reshape with your sure not to run washer without screens or could ruin valve and it won't shut off. also flush out fill hose before hooking it back up.
Mar 17, 2013 | Kenmore 24032\24036 Top Load Washer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
My kenmore 70 series wont stop filling with cold water. the hot water stops filling.
you need to replace the water inlet valve on back of washer as the cold water side is not opening,it's easy,remove the 2 top head screws,flip the head up,use a screw driver to pop the 2 clips out(1 on each side top),unplug the wire jack,now pull the back,back so you can get to the valve-mike
Mar 21, 2009 | Kenmore Washing Machines
Cold water trickle hot water runs good
turn off water valves at wall, disconnect the supply hoses from the washer. where the hoses connect to the washer, there is usually a stainless steel screen/strainer inline on both the hot and cold inlet. corrosion on the cold side is pretty common. Menards, Lowes Home Depot stores sell the replacment screeens.
Jan 25, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series Water pressure turning up and down
it will switch from hot to cold and back and forth trying to regulate the temp. You probrbly have more pressure in your cold water line than your hot or vise versa. This will cause it to seem to pulse. Dave
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Leaking washer
Replace the valve, or if new, have them do it. You are sure it is the valve and not where the hot warter hose attaches? Confirm by hooking up hot water under preasure to see if that seals itself.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Washer produces Hot Water Only
first be sure you are getting a good flow of cold as far as the washer connection..if so ck inside washer connection for a small wire screen be sure it's not plugged if so clean and flish line to remove anything inside hose sure to put screen back in ..if still no cold suspect bad cold section of valve..replace valve..last remote possibility temp switch is bad
Sep 12, 2008 | Kenmore 24902 Top Load Washer
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Kenmore 12502 Top Load Washer Logo
55 people viewed this question
Sal De
 Brian Main
Brian Main
