Question about GE Spacemaker JVM1640SJ Microwave Oven
No heat microwave runs but doesn't get hot
  • GE Master
  • 5,568 Answers
It could be a failed magnetron or, if the supply for the magnetron is fused separately (inside), it may be a blown fuse.
If you decide to have it serviced, take it to a recommended shop since, in my experience, the Chinese maggies that one gets are not nearly as powerful as the original was.
A repair shop has to know his parts source well.
Posted on Jul 07, 2008
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
Mar 18, 2013 | Microwave Ovens
Runs but doesn't heat
if it has a turntable does it move? Possible diode, inverter board (may have the diode on it or the Magnetron.
If an inexpensive unit it may be cheaper to replace than repair.
Nov 05, 2012 | Emerson Mw8999rd Microwave Oven
Sanyo EM-SL40S microwave everything seems to be working fine but food doesn't get hot?
see this causes and fix it. GOD BLESS YOU
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Oct 01, 2012 | Microwave Ovens
GE Profile Spacemaker 2004 JVM3670BF02 doesn't Heat up
Ensure that you have select the correct range of temperature.
Sep 11, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Oven is not making etables heat
Mar 07, 2012 | LG Microwave Ovens
My Oster microwave (model #OGG21401) doesn't heat. When operating the light will turn on and the carousel will turn but food will not get hot. Can you provide a solution to my problem? Thank you.
Check the door safety interlock switches for proper operation. #1 trouble with microwaves that operate in all respects but no heat.
Thanks for your question @ FixYa.com
Sep 16, 2011 | Oster 0.7 Cu. Ft. Compact Microwave
Microwave runs but doesn't heat
HI>An oven is equipped with a heating filament that is called.Magnetron.Now if the motor is working but the unit is not heating .Then MAGNETRON is defective and must be replace.
Jul 22, 2011 | Maytag Microwave Ovens
The microwave turns on but does not get hot. The light is on, the the clock, the timer and everything works, except that the food does not get hot. I tried to heat up some water and doesn not change its...
you need to remove the outer cover,then carefully discharge the high voltage capacitor with 2 insulated screwdrivers or an insulated jumper wire,then test this and the high voltage diode and the internal ceramic fuse for continuity
Nov 15, 2010 | Amana ACO1860 Microwave Oven
The microwave timer runs but turnable plate doesn,t rotate and the heating elements doesn't comes on
you need a new microwave. There are no heating elements in mocrowaves just micro-waces. It only heats moisture it does not heat objects. It is to dangerous to replace the actual device that heats liquids.
Jan 24, 2010 | Emerson Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
111 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
