There is a reset button in both units, press one and then press the other right away and that should get them taalking to each other. use a paper clip, the reset buttons are located under the battery compartments
Usually replacing the batteries in both units solves this problem. if not, try moving units closer together - you can try this in 1 foot increments. if you still have problems - evaluate whether you have added any other cordless or remote devices around the time this unit quit working. if so, create more distance between your thermometer and the offending unit by relocating one or the other (you can test this first by turning off or unplugging the new device for several minutes while you check the signal on the thermo).
If this all fails- the units are typically not serviable by the DIYer. if under warranty contact Oregon Scientific and send back. if new - back to store. If older unit you may need to rplace the outdoor unit which can be ordered online.
good luck!
