Question about Husqvarna Viking 1
Needle doesn't move the problem isn't the foot pedal
I love this sewing machine it's a Husqvarna Viking 400, but the needle will not move up/down when I step on the foot pedal.
I have taken it to a dealer in Missouri, but Missouri is NOT a Husqvarna state, (they like their Babylocks here) so the help was less than helpful. He thought maybe the issue was a transformer, but isn't getting back to me with a fix it cost. The machine powers up fine and the foot pedal was tested on a different machine, so that's fine.
I'm thinking I may list the machine for parts on Ebay, but I'm hoping to find somebody who really knows Husqvarna Sewing machines as a last effort. I'm in mourning for my machine.
Oh one other question. Really how long should a computerized sewing machine last?
Thanks aot.
  • Norm Himebaugh May 11, 2010
    Have you been successful fixing your Viking 400 or do you still need help?
I have a pfaff machine. the needle won't go down all the way. When I twist the wheel, it will only go part way. I've cleared all the bobbin thread and nothing works
Posted on Jul 24, 2008
I have a Husqvarna #1 that I also love. My needle stopped moving too. I was convinced it was the foot peddle but a repair person sais it was not. I discovered on my own that indeed it is the cord on the foot peddle. I suspect it has a loose wire because when I wiggle it where it connects to the machine it starts working again. Right now this is what I have to do because I can't find a replacement peddle. Can anybody help me find one?
Posted on Jul 21, 2008
Same problem with my 400. I took it in to dealer and they said main computer board on my machine would have to be replaced. Fortunately, they agreed to get it fixed for me. My machine is 2 years old. How old is yours? I wonder if this could be a manufacturer defect on the machine? Maybe this needs to be addressed with Viking Husqvarna Corporate.
Husqvarna viking 300 sewing machine bobbin winder will not stop spinning. machine will not sew when foot pedal depressed. bobbin winder just keeps spinning.
The bobbin winder moves a plate next to the handwheel that disengages the needle from moving If you can't push it back to the left you will have to take the machine apart to fix it.
Jun 10, 2017 | Husqvarna Sewing Machines
How to wind a bobbin for a 250 electronic Viking Husqvarna machine
Make sure that the presser foot is raised if you are winding a bobbin with the top thread threaded through the needle. Place the bobbin on the spool spindle with the mark (a stylized H) outwards. Bring the bobbin spindle down. Next pull the thread from the needle under the presser foot to the thread guide on the right. Bring the thread above the bobbin and wrap the thread around the bobbin several times. Cut off the excess thread on the thread knife and step on the foot control to wind the bobbin. When the bobbin winding is finished, remove the bobbin from the spindle. Cut the thread to separate the bobbin thread from the needle thread. Move the bobbin spindle up.
Sewingpartsonline.com has a link to the manual for the Husqvarna Viking 250 on the machine specific parts page (under Manuals), http://www.sewingpartsonline.com/viking-250-sewing-machine-parts.aspx . The direct link to the manual is http://manuals.husqvarnaviking.com/VSM/Husqvarna%20Viking/HVManual.nsf/5bc6115484660075c12575d2003f80e3/ecf97dd171581582852575ed00755e7a/$FILE/Viking%20210,%20230,%20250%20%20x.PDF . The bobbin winding steps are on page 12. There is also a method for winding a bobbin with a different thread from the top thread. See the manual.
I hope this helps.
May 28, 2017 | Husqvarna Sewing Machines
Foot control does not work
Does it work by pushing the Start/Stop button. If so the problem is probably with the foot control. Make sure all connections are secure. You may need a new foot control. Contact your local Viking Dealer and try one of their foot controls to determine if it is indeed the foot control or something else. You can find your nearest authorized Viking Dealer from the Viking website - http://www.husqvarnaviking.com/us Click on Locate a Dealer for your local dealers.
Jan 28, 2014 | Husqvarna Viking 1
THE NEEDLE WILL NOT GO UP AND DOWN
if the needle bar doesn't move the needle up & down then the machine needs to be serviced, to find out why it isn't moving
May 01, 2012 | Bernina Sewing Machines
Why isn't my husqvarna foot press not connecting giving power for my needle to move. Machine does have power but does not run when pressing foot press.
have you checked to make sure the foot pedal is connected correctly to the machine?
if the foot pedal is connected correctly, then the machine needs to be checked to see why it's not responding
Mar 27, 2012 | Sewing Machines
Husqvarna model 183 foot control no power
anytime the machine does not respond like it's suppose to then it needs to be checked, the foot pedal could have gone bad, or the the sewing machine plug where the foot pedal goes may have gone out
Mar 27, 2012 | Husqvarna Viking 1
My Husqvarna Viking Emerald 183 has always had a problem with the needle up needle down button - after pressing it once, it often sews anywhere from 3 to 20 stitches. More recently, the machine keeps...
There is a sensor on the upper shaft that recognizes the position that the machine is in. A small disk on the upper shaft that has sections removed from it will block the sensor trough some range of operation and not at other times.I have never seen this in a 183, but you may have a sensor that is misaligned so that it doesn't completely block or clear the beam of light.It will need to go to an authorized repair center for repair. Some of these parts are very delicate. Don't risk damaging something working on it yourself.
Nov 06, 2011 | Husqvarna Viking 1
Have Viking Husqvarna #1+ sewing machine that when filling a bobbin caused the bobbin to overfill and break. Now when pressing the foot pedal the needle will not move. I can manually turn and get the...
Make sure that the bobbin winder stop is up. That is the little black post below the bobbin winder. If it is pressed down, the machine will not run.
Feb 02, 2010 | Husqvarna Sewing Machines
Fabric stuck when sewing
Several things could be happening. It may be the hook/needle timing. Or it could be the feeddogs are not moving (that's the toothy looking part under the presser foot that moves the fabric). Recommend removing thread and bobbin (needle and presser foot). Slowly move the handwheel and put your finger on top of the feeddogs to determine if they are moving back and forth and are high enough to move the fabric. Check to make sure you had not manually lowered the feed dogs. You may need to take it to an authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Nov 21, 2008 | Husqvarna Viking 1
Sewing Machines Logo
409 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
