There is very very little air coming out of the unit. Not strong at all.
    Problem Solver:
  • 18 Answers
Could be a stopped up air filter, dirty evap coil or your blower wheel is dirty and or freezing up. See if the larger refrigerant line is freezing up where it leaves the evaporator coil going to the outside unit
Posted on Jul 06, 2008
When I turn on the air conditioning, why is very little air coming out of the dash vents?
Probably needs a recharge easy to check go to auto store get a kit hook it up turn on a/c full check gage and charge to level
Mar 30, 2015 | 2004 Dodge Dakota
Ozone smell
When the unit is clean it will produce more ozone. If the unit is a bit oversized then it becomes worse. As an installer I have to be carefull to not oversize these units. O3 is harmless and actually will only stay in the air as O3 for about 1/2 hour. Because of this it will not build up in the air. O3 also in a powerful disinfectant and will help kill mold and bacteria in the air. As soon as the filter gets a little bit of dust on it the O3 production will become much less. Run your fan continuously for a day or so and it will go away.
Nov 15, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Ammonia smell
bad cooling unit Freon leaking cannot fix replace cooling unit or whole unit
Sep 25, 2009 | Dometic Rooftop RV Air Conditioner
Turned air on but outside unit will not come on at all
when you say a little air could the filter be plugged up or the coil iced up is the outside unit running
Jun 20, 2009 | Carrier 38CKC036 Air Conditioner
I have a dometic duo-therm. No air coming through ducts.
Sounds like the ducting have come apart in some areas or blocked in some way. Take the supply grills off and with a shop vacuum try and reach as far as you can.
Mar 18, 2009 | Dometic Rooftop RV Air Conditioner
RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Mar 24, 2008 | Dometic Rooftop RV Air Conditioner
PROBLEM
is this a heat pump, mini split?
Feb 20, 2008 | AmcorAire UCHW-H24AF2 Split System Air...
24000 btu split ac unit... celiera brand... BIG PROBLEM
is this air inside or out that is cold and cloudy?
Feb 19, 2008 | Fujitsu 24R1 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
