Question about ASUS P5W DH Deluxe Motherboard
No video output on either video out ports. Please help I was in the process of doing an adaware scan and playing solitaire while it was running and PC hung. ctrl-alt-del did'nt do anything, no mouse, no keyboard so powered off to reboot and had no video. Have an ASUS P5WD2 premium MB, Sata HD, MSI 8600GTS Video, Antec PS., BENQ monitor. Have tried another video card , 2nd PCI ex16 slot, other video out connector on video card. no power on video although the cd rom & hd read lights flash on and off.
    President:
  • 2,351 Answers
You mentioned you placed "another" PCI-E card into PCIEX16_2 slot.
You need to remove the video card from the PCIEX16_1 slot first & try the second video card in PCIEX16_1 slot. Page 2-4 in manual.
Boot the system & see if you have video. If yes than the other PCI-E video card has an issue.
Just adding a second card will not boot.
You do want to replace the video in slot 1. This way you do not need to make any changes in you're bios or add the additional power (Which is required to run both at the same time). (Kind of hard to get into the bios when there is no video display).
Luck!
Mike
Posted on Jul 06, 2008
Hdmi ports not working
reset your playstation 3 video setting
Reset Video Output
If you are changing cables or cannot see an image on the screen, you may need to reset the video output to default settings. To reset the video output:
  1. While the PS3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the PS3 beeps a second time (approximately 5 seconds), then release it.
  2. The PS3 will power up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 21, 2013 | Sharp AQUOS LC-40LE830U 40" LCD LED HDTV
Tip
How to convert iTunes videos to unprotected M4V format playable on iPod
M4V Converter Plus is a powerful M4V DRM Removal tool. It converts M4V videos to MOV format in high speed with great quality. It is designed to convert DRM M4V video you purchased to QuickTime MOV, iPod, iPhone format. Moreover it can also convert almost all video formats could be played on your iTunes to other common video formats like MOV, MP4 or unprotected M4V.
Follow the steps, you can convert your DRM M4V movies to iPod supporting M4V fomat easily.
Step 1: Load M4V movies you want to convert.
Click "Add Movies" button, search your DRM M4V files according name, then select the files, click "Add" button.
Step 2: Select output format and output folder.
In the output droplist, select "For iPod (*.m4v)" in profile droplist.
Tip: If you choose "For iPod (*.m4v)", the output video is for iPod, and the video maximum size is 640*480.
Step 3: Start Converting.
You can press "Convert" button or click the menu Control->Start Converting to start the converting, and now the converting process begins.
Step 4: Check Output video files' Quality
After the converting process finished, you can select one of these video files, and then play it to view video effects whether it is satisfied. If you are not satisfied, you can re-customize the output setting to convert the video to other format to meet your need.
Step 5: Find the converted files quickly
After you open the converting box, you can see the default output path is/Users/username/Documents/M4VConverter Plus, but you can click the button Browse to customize the output location as you like. And Click the Open button to view the output folder quickly.
If you check the "Open folder when conversion completed", after all the files converted, it will open the output path.
You can find more info at
M4V to iPod convert M4V to iPod with M4V Converter Plus
on Feb 05, 2015 | Apple Computers & Internet
Tip
How to convert iTunes TV shows to Galaxy s
In our daily life, most used is iTunes, if we purchased movies or music songs from iTunes Store, they can only be supported by 5 players produced by Apple Inc. And if we want to want to play them on our non-devices like Galaxy s, M4V Converter Plus comes to help.
Download, install and run the m4v converter.
Convert Any iTunes M4V to MOV
on Feb 05, 2015 | Samsung Galaxy S
How to convert a videos
Launch your video converter program if you have one.
If you do not have a video converter program, consider free programs such as AVC Video Converter http://download.cnet.com/any-video-converter/3000-2194_4-10661456.html
or
Prism Video Converter
http://dw.com.com/redir?edId=3&siteId=4&oId=1770-20_4-0&ontId=2194_4&lop=linktitle&ltype=dl_elite_gen&pid=12172333&mfgId=10012381&merId=10012381&ttag=lst-1&destUrl=http%3A%2F%2Fdownload.cnet.com%2FPrism-Video-File-Converter-Plus%2F3000-2194_4-1064
These programs are cross-platform applications, compatible with both Windows and Mac OS X operating systems.
Click "Add Files" or "Add Video," depending on the program that you are using.
Locate the video file you want to convert from the folder you saved it in, then click "Open" to import it to the video converter program.
Play your video on the monitor to ensure that it is the video that you want to convert.
Select the video format you want to convert your video to in the "Output format" or "Profile" window.
Choose from a number of video formats, such as MP4, AVI, MOV or WMV. Different models of MP3 players use different video formats, so refer to your MP3 player's documentation for the compatible format.
Select the output video size you want to use. Video sizes vary with different MP3 players. Some MP3 players support 320x240, while others support 640x480.
Refer to your MP3 player's documentation for the supported video size.
Select the audio codec that you want to use for your output video file.
Some of the most common audio formats include MP3, WMA, AAC and WAV.
Audio codecs compress audio with different output quality settings, so refer to your MP3 player's documentation for the supported audio codec.
Select 2 or "Stereo" in the channels box for a balanced left and right audio output.
Click "Browse" and select the folder where you want to save the output video.
Select a folder or location that you will be able to remember and access quickly.
Click "Convert/Encode" to begin the video conversion process.
A status bar displays the progress of the conversion.
When the process is finished, your video is in the format that you selected
hope this helps
Sep 27, 2012 | Audio Players & Recorders
I want to pair my laptop (lenovo N100) to my mobile (samsung corby tv) i could not find the pin ? please give me the steps
Does your laptop have a VGA-output port? an S-Video port? a HDMI output port? component-output port?
Does your TV have a VGA-input port? an S-Video port? a HDMI input-port? component-input ports?
Match the "output" to the "input", and you should be OK.
Jul 03, 2010 | Computers & Internet
How do I play my games on tv using av cable?
The PSP system (model PSP-2001 and PSP-3001) includes a video-out port which allows users to connect and play the PSP system on an external display or television with AV inputs. It is important to note -- you can
Component AV Cables (model SCPH-98550)
The Component AV Cables connect to the Video Out Port on the bottom of the PSP-2001 or PSP-3001 systems and allow you to output video and audio signal to a television display. The AV Cables support photos, videos (including UMD movies), music, and games. Please note for games to output onto an external display, the display must support progressive scan.
Composite AV Cables (model SCPH-98548)
The AV Cables connect to the Video Out Port on the bottom of the PSP-2001 or PSP-3001 systems and allow you to output video and audio signal toa television display. The AV Cables support photos, videos (includingUMD movies), and music. However, output of games are only supported by PSP-3001.
Sep 28, 2009 | Sony PlayStation Portable (PSP) Slim...
PSP2000 SONY GAME
no you cant... the t.v screen cant support the games of psp.
Mar 11, 2009 | Sony PSP (Piano Black)
The HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
Jan 10, 2009 | Yamaha HTR-6140 Receiver
Connecting my laptop to my Samsung DNie 29' Tv
Are you connecting the S-Video directly into the video output port of your laptop? S-Video 7pin? Video output port 7 pin too?
Is there an adapter for the video output port, for your laptop?
Aug 14, 2008 | Dell Latitude D600 Notebook
Firewire connection for ps2 output
The I-link S400 port does not supply power to devices.  If your tv requires a powered S400 port, then the port is not capable of working.  Check the instructions for using firewire on your tv to see if it requires a powered S400 port.  From my experience, the S400 Firewire port is not a video output. The network connection your calling firewire is a slve type situation because is does not have a power output. You can connect the PS2 into a IEEE 1394 network, and that is supposed to be plug and play.
Oct 12, 2007 | Sony PlayStation 2 (PS2) Console
ASUS P5W DH Deluxe Motherboard Logo
456 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
