Question about Mitsubishi WT-46805 46" Rear Projection Television
Bad picture Has a blurred vison at top and three different color lines are showing also at bottom .
  • 927 Answers
Good Day, tater5;
Sounds like you have a convergence problem. If the picture is bowed, please repair as soon as possible before 'the problem' causes additional concerns. It sound's like the 'conv' IC's have failed.
If you are handy the convergence IC's are big and black and attached to a large heat sink and will have numbers like STK 392-something.
Not handy? Then call a factory authorized service dealer to fix this for you.
Good Luck, big IRISH.
Posted on Jul 25, 2008
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
Blurred color images
I'm not sure of what brand and/or model you have, but most have a maintenance mode to do color alignment.
Jul 16, 2009 | Office Equipment & Supplies
RCA HD52W59 Projection Big Screen TV
you have cold solder conections if you know how to solder you can fix it with a good light
Oct 14, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
My rca home theater tv guide plus mod#p52820BL
Can you try using a different video cable?
May 08, 2008 | Televison & Video
Blurred colors and bowing top and bottom
the problem is the convergance and would need to have the amps replaced. may be some resistors as well. the repair may cost $350.00 or so. there is no bulb inside just three CRTs which are no longer available for your set.
Mar 02, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Seperated colors
this is a common problem you have bad solder connections on the convergenc ics solder them back if this does not fix the problem then replace them k
Nov 03, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
60" Ultravision picture problems
HMMMM Dual pictures This is a problem that every projection TV runs into at least once or twice in its lifetime. Its the old convergence IC falure thingy. These IC's go bad and should be replace all at once. These are not consumer replaceable unless you have had training in the electronics or TV repair fields. Please call out a pro to assist you with this repair as A TV is not the place to experiment in because of the HI voltage and saftey issues. Good Luck
Jul 29, 2006 | Hitachi 50DX01B 50" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
