My Rheem ac unit is iceing how do i fix it - Heating & Cooling
    Problem Solver:
  • 18 Answers
Your best bet would be to get someone to check it, you have a low refrigerant or air flow problem
Posted on Jul 06, 2008
Is my Rheem AC still under warranty? I cant reach the installer. I have the model and serial #s. Cant find a customer service # for Rheem!
Any contractor will be able to honor the warranty. If you are the original owner of the equipment and the paperwork was filed properly you will still have a warranty.
Nov 19, 2016 | Heating & Cooling
How many pounds of reon do you put In 2011 Rheem Classic packaged ac unit
look on the mane plate on outside unit... has voltage ratings model serial type of freon factory charge etc.
Jul 21, 2014 | Rheem Prestige 14 Series 4.0 ton 14.5 SEER...
Aircondition builds ice on coil
Either lack of refrigerant, stopped up metering device or capillary tube/s, or lack of air flow (due to bad blower motor, or dirty indoor coil) Good luck.
May 19, 2014 | Rheem Complete Split System Gas Furnace 5...
Heat Pump Blowing Cold
Unless you just installed or had the thermostat installed recently, I would not point at the thermostat as the problem. With what you have described I would suggest have your units serviced as it sounds like a loss of charge, or failed defrost control board. The "Aux" comes on when the unit is using secondary heating (electric heat strips). That occurs when the demand temperature (what you set it to) in Heat mode is more than the current room temperature, usually ~2-4 degrees higher. Also happens in defrost mode. Defrost is a heat pump cycle that melts any build up of ice on the condenser unit (outside unit). That process is simply the unit running in cool mode which will heat up the outside unit to melt any ice. Defrost cycles vary with manufacture but usually you can tell if is in defrost by looking at the outside unit, during defrost the unit will be warm or hot sometimes there is steam and the compressor will be running but not the fan. Defrost only happens on heat pumps in "Heat" mode. Rheem has a 10 yr compressor and parts warranty, so call the installer or Rheem authorized service company.
Nov 11, 2013 | Honeywell RTH7600D Touchscreen 7-Day...
Replace contacts in ac rheem 060jaz split system were is reset switch
Get wiring schematic check wiring and the restet is turning breaker on and off to unit. Furnace included. Start checking for 24v . To contractor and through pressure switches. 208-230 volts in unit. Beaware
Sep 06, 2013 | Heating & Cooling
MY A/C PORTION OF MY UNIT RUNS BET DOES NOT BLOW OUT COLD AIR. THE UNIT DEVELOPES ICE ON THE COILS. I HAVE A RHEEM MODLE: RRK-A030JK08E UNIT
Hello
Possible unit is low on freon,also inside coil should be cleaned,change filter.
Usually ice on coils is low freon.Will need a service person to find leak and recharge.
Apr 21, 2011 | Heating & Cooling
I have a rheem air conditioner and the fan spins and it pushes air but the air is not cold enough?
hi! there,
well we have to do something about that,if you mention of fan spin and it pushes air but no cold enough on it,this refer to blower on compressor, there is fan on outside the condenser,so we are on blower w/c does not blow enough cold air,there are factors we can check,first thermostat try to adjust thermostat to the coldest point,
observed if cold was increasing if not, 2nd have clean the filter from evaporator it may have a clogged, check evaporator if there freezing ice on bottom portion of evaporator w/c cold was coming out,have it clean,cleaning this is done by certified a/c technician,there is problem if have an insufficient cold,this is the symptom of your system was under charge lack of freon,this can check by technician w/ clamp ammeter device.the operating current should be equal to rated current on manual,inform service center about this,have a nice day don't forget to rate me.thanks's
Apr 20, 2009 | Ruud UBHC Air Conditioner
I have a Rheem ac unit for a trailor. The wiring
Red goes to rc/rh
White to W
Green to G(fan)
Yellow to y
If a common it's usally blue or black
Mar 10, 2009 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
