Question about Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier
GP Professional Series Ionic Breeze - Simply Quit Working
Unit made a 'popping noise' and will not come on at any setting. Grid seated, not dirty and ultraviolet bulb looks good continuity checks 'OK'. Have verifed outlet has power.
Is there a circuit braker/fuse accessable within unit? Is a power supply issue with this model. (Have two much older units that work fine) This unit is two years old, others are 4 years old. BLUE LIGHT COMES ON WHEN PRESSED THAN AFTER 30 SECONDS GOES OUT...DOES NOT PICK UP ANYTHING ON THE GRIDS AFTER RUNNING FOR 12 HOURS
  • krisval Jul 08, 2008
    Ours just stopped working. It is clean, the power works, but nothing.
  • Anonymous Sep 01, 2008
    My Ionic Breeze Quadra just quit - no lights at all when plugged in.
  • 2,794 Answers
Sharper Image models are no longer supported because they have been recalled since they were proven to be ineffective.
Here is a link about the Chapter 11
Here is a link for the EPA about ionizers
Posted on Jul 12, 2008
Popping sound
SOUNDS LIKE THE ELEMENTS ARE DIRTY. FOLLOW THE DIRECTIONS IN YOUR OWNERS MANUAL TO CLEAN THEM.
Mar 03, 2010 | Sharper Image Professional Plus Ionic...
I have a professional series ionic breeze gp. It stopped working and has a red light on-something I had never seen before. Can you help with this model?
Well there is a small micro switch that is actuated by the grid. This is mounted on the side of the top control piece. There are two wires attached to the little circuit board, usually one is corroded so you need to cut it back and soder it to the center pin of the switch. also check the fuse.
Good Luck!!
Thanks
Sep 20, 2009 | Sharper Image Ionic Breeze 3.0 Air...
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
Where can I buy replacement grid for ionic breeze professional series model S1831?
G15T8 15W 15 Watt UV Germicidal Bulb IONIC BREEZE GP
Item number on ebay is: 220444965077
$10.99 plus around $5 to ship.
Pull up on the tab on the bottom of the front filter and pull up. You then should be looking at the bulb, which you will turn 1/4 turn (2 clicks). You should then be able to pull the bulb out.
Hope this was helpful.
Jun 10, 2009 | Sharper Image Professional Plus Ionic...
Ionic Breeze Hybrid GP air purifier only 1/2 grid gets dirty.
I have been doing research on this unit. I read that only every other grill is suppose to collect. The remaining grills increase the electrostatic charge making the collection plates, the ones that get dirty more effective. So the bottom line is there is nothing wrong with your unit.
Apr 24, 2009 | Sharper Image Hybrid GP (SI724) Air...
Sharper Image Design Ionic Breeze GP Professional Series Mod 1861
My professional series Ionic breeze GP blows out what seems to be clean air but the purple lights inside it are no longer working. Can anyone tell me where I can find replacement bulbs or just what I need to do to get it working again. I got it as a gift 4 or so years ago. The gift giver says there was a 5 year warranty on it but I am not sure. Any advice would be helpful.
thank you. Nicole
Aug 28, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Ionic breeze gp grid
This is where you go to get what you need......
Hope this helps....good luck and thanks for rating my effort....the Fang.
May 31, 2008 | Sharper Image Extra Grid for Ionic Breeze...
Ionic breeze is arcing inside unit
I have a sharper image ionic breeze hybrid gp that ran fine for years unitl it recently started sparking / arcing at the base of the grid blades and always in the same spot. I cleaned it several times but the sparking always came back and the unit went into either "drying grid" or "attention required" mode. The solution I found was to stand the removable grid in 2 inches of Pine-Sol cleaner 50/50 diluted with water for 24 hours then brush again with the cleaning brush and hot water. Presto! No more sparking.
Oct 16, 2007 | Sharper Image Ionic Breeze GP SI730 Air...
Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier Logo
929 people viewed this question
Top Sharper Image Air Purifiers Experts
martinmarty
Ken Thomas
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
