Question about Kenmore 22422 Top Load Washer
Kenmore elite washmachine
Part way thru the cycle, it stopped (with water in the tub) and is flashing FL.
    Genius:
  • 1,224 Answers
Kinked hose adjust hose so unkinked
or water pump clogged sometimes socks get past drum into water pump
water pump sends the water out
these are the main reasons the washers wont drain
couple things needed for pump removal
bucket and a couple small cups
pull water out
once low disconnect power turn the water off disconnect
you will need someone strong and a dolly
take out side the little water left in will make washer heavy
once outside tip back lay down on side angled up a little pull pump out pull debry out with needle nose pliars 2 people needed here then put pump back in done
this is self service solution
this can be done without service person
or you could call maytag
Posted on Jul 07, 2008
Kenmore elite washing machine with calypso - cycle ended with water in tub after partial wash of 3 towels, signnal was LD - re-started machine and it stopped with signal FL - machine will not re-start
Fl stands for flooded. Either your pressure switch is bad or plugged in the tubing from the tub to control panel or the sensor is bad. But check and make sure the water is draining or pumping out like it should, if not the problem may lie in your drain pump or hose.
Mar 13, 2011 | Kenmore Washing Machines
Washer won't drain..like filter is clogged
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%@#$
Mar 27, 2010 | Kenmore Elite 21082
Kenmore elite washer model 21082000, won't
Flood Condition:
Feb 19, 2010 | Kenmore Elite 21082
Machine stoped after wash cycle tub did not drain and reads F L kenmore elite calypso model #22064 100 type 170 cannot get it to start at all it keeps beeping and reads FL
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%#@$
Feb 09, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How do you reset the overfill switch on the kenmore Elite calypso machine? It shows FL and we cut the power. There is water inside
Flood Condition:
Nov 15, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite reads fl and stops working,
Flood Condition:
Jun 16, 2009 | Kenmore Elite 45986 Front Load Washer
Code FL, won't empty tub on last cycle
FL = Flood condition
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
May 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Calypso 21082
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@
Dec 16, 2007 | Kenmore Elite 21082
FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. This could just be a fluke, or you could have a possible bad pressure switch that is not shutting off the water supply correctly. In addition, fill valves have been known to short out causing water to constantly fill in the wash tub. Lastly, your household water pressure could be too low and won't shut the fill valves off properly. Inlet water pressure should be a minimum of 10-20 psi. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display. I hope some of this leads you in the right direction.
May 12, 2007 | Kenmore Elite 21086
Kenmore 22422 Top Load Washer Logo
66 people viewed this question
fordexpert
Archaeology
Archaeology
