When the set is turned on the top 4.5" of the screen appears to have a milky white substance covering it. It is somewhat transparent (more opaque, but you the characters behind (beneath it) are hard to discern. This problem increases with each set turn-on. Is the tube shot, or can it be remedied?
  • 4 more comments
  • searlesjs Jul 07, 2008
    This is not for a projection TV- the affected set is a regular 27". The affected area is 4 - 5 inches and growing.
    It is a JVC, Model # AV-27230
    Hi Jamie- I've never done this type of repair-would it make more sense to take it to a repair shop?
    Hi Jaime- how much do you think these repairs might cost? Thanks,John.
    I am interested in an estimate of the cost of the repairs per jaime867. thanks.
    The advice was great!
    Genius:
  • 2,035 Answers
This could the problem with weak capacitor or the weak picture tube... IT may cost you 50 to 300 $ depending on the problem.....
Posted on Jul 07, 2008
  • 13,433 Answers
If you plan on replaceing the parts yourself less than 100, if you take it to a tech the price can go anywhere from 200 to 500
  • 2,307 Answers
Can you please provide model number of your TV?
  • 2 more comments
  • Jaime Hernandez Jul 07, 2008
    There seems to be a capacitor(s) that are becoming defective nearby the vertical output amplifier.
    The picture tube is fine as this defect is located in a different area of your TV circuitry.
    The parts that need to be replace are label as C424, C425 and C434 and they are located near IC421 with the following makings LA7840 that is mounted on an aluminum heatsink.
    NOTE: Before you do any work if you are planing to, unplug the TV for at least 12 hours to allow the high voltage capacitors to drain their charge.
    Let mek kow if you require further assistance.
    If you have not done this kind of work before is best if you could take it to a repair shop but if they tell you that the CRT(tube) is bad just to charge more, tell them more or less the parts that they will need to replace.
    Good Luck.
    I would say that a fair price to pay for the repair should be about 1/3 of the price of the TV.
I HAVE THIS 2005 CHRYSLER PACIFIC HAD TRANSMISSION FLUSH AFTER DRIVING IT ..IT OVERHEAT NOW WHITE MILKY SUBSTANCE IN COOLANT RESAVOIR WHY ??
You need to check the oil and see if the dipstick shows overfill on oil or if you see the white milky substance on the dipstick you may have a blown intake gasket or head gaskets. I would think it sounds like a blown head gasket. Hope this helps.
If you are adding water to the system you have a problem somewhere you might want to run a compression check on the cylinders to see if you have a intake gasket leak or a head leak. How hot did the car get because you might have cracked a head. If you don't see the water in the oil it may be exhausting out the tail pipe.
Sep 14, 2015 | Chrysler Cars & Trucks
Gritty substance in the ice cubes and icicles
Clean and descale the inside waterways with ice machine cleaner. Check hoses for leaks. Instal in-line filter
Apr 04, 2014 | U-Line Kitchen Appliances - Others
I have a Sharp 36F-630 36" TV. Recently, it started getting a "band" across the top of the screen. It gets smaller as the tv warms up. It used to go away completely. Now it goes from...
You have a swollen capacitors in the vertical section try to replace all the leaky capacitors, you will notice that there is a liquid leaking out in the buttom of the capacitor.It is like an oil spill.
Dec 06, 2010 | Sharp 36F-630 36" TV
White milky substance in oil resevoir
no that is cause dby oil and coolant mixing together
Apr 29, 2010 | 2002 Mitsubishi Lancer
White milky oil substance in the oil resevoir
due some droplets of water entering into it k
Visual transparent lines at top of picture
You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
Oct 15, 2009 | Philips 27PT6441 27" TV
Model 665 16874
removed and disassembled inlet water valve - minature basket filter was clogged with white particulate which felt gritty.  cleaned and reassembled and reinstalled.  Works fine now.  Idiot repairman never mentioned a filter but wanted to replace entire valve at cost of 140 dollars including service call.   sears sux bigtime. And, from my experience with Fixya, so does your service since I never heard a thing since July EXCEPT for an offer to upgrade.  Thanks for nothing.
Jul 11, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Monitor turn on but only a black background appears
Is that white substance heatsink greese that's been burned up or the transistor fried with some melted tape?
Jul 03, 2008 | Dell E173FP 17" LCD Monitor
Milky sustance in radiator
it is motor oil toyotas are not made to run hot u have a blown head gasket it is also a good idea to replace ur timing belt while making the repair and flush ur radiator before runnning motor after repair
Jun 15, 2008 | 1993 Toyota Camry V6
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
