Question about Harman Kardon FL8385 5-Disc CD Changer
I had a cd jam,took cd changer apart, now the door won't close all the way
The 5 cd door does not close all the way. The door sticks out approximately 1/4 inch. I had a CD dislodged and removed the top and then removed the CD. The 5 disc holder is aligned with the detent in the machine so it closes in the proper orientation but it does not close all the way. Obviously something is preventing it from closing but I can't find it.
  • mclewis Jul 12, 2008
    HI, I have the same problem.  The CD door won't close all the way.  It stays
    ajar about a quarter inch and the machine won't play any CDs.  I've tried turning it off and on, unplugging, forcing a little, opening and closing using both the xchange button as well as the open/close button.  Even turning the maching upside down in the hopes of unlodging what I think is a CD that is stuck somewhere on the inside.  No luck so far.  What to do?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 15 Answers
Robotek is 100% correct. I've just fixed the very same problem and posted the process here on Fixya and KeepAndShare.
3.7mb PDF
Fixya:
http://www.fixya.com/support/r3817945-harman_fl8385_cd_changer_tray_alignment
KeepAndShare:
http://www.keepandshare.com/doc/view.php?id=1660661&da=y
Posted on Jan 06, 2010
  • 1,512 Answers
Hi artzelda
The machine tray carousel may have stepped out of alignment after jamming on the dislodged CD and is catching on the CD transport assembly on the way in. on the way in. This problem can generally be solved by retiming the tray mechanism. This is one of those jobs that takes some perseverance and an understanding of the transport. If you don't have a head for mechanical things, this may not be something you can fix yourself. A HiFi repair guy would. Should be minor charge.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jul 07, 2008
The tray will not open. I loaded the cd's into the changer, closed the tray and it sounded like one of the cd's may have slipped. It does not change or play.
my friend u r going 2 have 2 take it apart. you will have 2 unscrew 4 or 6 screws from the side or bottem 2 take off the top a take out the cds yourself. its not hard 2 do.just remember tht a disk changer can b off track. its possible 2 pull it open but dnt do it if u will break the door track
May 09, 2011 | Denon DCM-290 5-Disc CD Changer / Player
Jvc xl-f254 cd changer for home. 5 disc changer. Carousel will not slide out. makes humming noise, possibly trying to open.
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
Jan 29, 2010 | JVC XL-F254BK 5-Disc CD Changer
5 cd changer tray wont open
just opened the dvd player..took out the jammed cd and it's working properly now...saved me 55$ for a check or was advised to buy a new one costing 400 odd $!
Jan 21, 2009 | Philips CDC775 5-Disc CD Changer
Cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Nov 28, 2008 | Denon DCM-360 5-Disc CD Changer
Cd jammed
Hi there!
That happened to me before and what I did was tried to press the eject button and carefully pulled away the changer and it worked.
You just need to be patient though since it took me days and proper timing before I took it out.
Hope this helps.
May 02, 2008 | Car Audio & Video
Jammed cd player
You can fixed the alignment of the disk tray of the CD player. But its pretty cool if the repairman in your nearest location would you let do the job.
Jan 06, 2008 | Audio Players & Recorders
Cd jam
try dismantling the shell and check for any jammed object or broken pieces that might cause the door jamming. if it is a matter of a stuck object that somehow got there, you can remove it and hope for the best. otherwize, you will have to replace the broken pieces, or the whole part.
Mar 11, 2006 | Panasonic SC-AK220 CD Shelf System
Harman Kardon FL8385 5-Disc CD Changer Logo
182 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
