Washing Machines Logo
craig Wilis Posted on Dec 27, 2010
My Candy sprint 1300 washing machine wont spin to drain water from my clothes
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Dec 27, 2010
Anonymous
Contributor
Level 1:
Answers
20
Questions
Helped
4942
Points
64
These washers have a printed circuit board that is know to burn out some components.If you can locate it and remove it, it can be resoldered at a local electronics shop, if your not confortable, most appliance repair shops can change this board at a reasonable cost. Hope this is helpful
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
My machine is just over 2 years old and the clothes are still wet after spinning at the 1300 cycle. Is there something I can do to fix?
Make sure all the water is drained out before the spin cycle and the water pump is working on the spin cycle.
How do I turn my candy sprint 1300 washing machine on?
Hug it tightly and give her a long wet hot kiss , it will be turned on instantly, good luck
Machine starts to spin out of control
Both problems could be related to a blocked drain, from what I can see in the manual. 3 Things to check -
1. Clean the filter - instructions can be found on age 24 of the manual.
2. Check the drain hose has no kinks/securely fitted.
3. Check the drain trap under the sink for blockages. Make sure waste water can drain away freely.
Keep a couple of old towels handy when checking the drain filter, if water is trapped in the machine, it will flow out of the filter housing when you remove it. Try a drain cycle for a minute or two before you remove the filter, then turn the machine off, and check it. That way you'll have drained as much water as it will allow.
The manual can be found here- http://service.candy-domestic.co.uk/manuals/pdfs/CNW156.pdf
My washing machine Candy CE10 does not spin and drain water
HI. firstly have you checked that all dirty water outlet pipe is clean and not blocked. or the cycle circuit could be broken.
6helpful
3answers
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
1helpful
My washing machine wont drain water
if waser wont drain it cant spin and some contorl boards get confused about that situation.check your pump,is it clear will it funktion.other wise i dont know a lot about this proticular machine god bless,tom
2answers
Will not drain
Try cleaning the filter as when this gets all clogged up the water doesnt drain thru the pump
1helpful
2answers
Candy CN146
0I have a candy intergraded washine machine ,could you tell me where the filter is please as the wash finish but still has water in, I put the cycle on to the water discharge and it emptys,then i put it onto a spin which works fine. But i need to know the problem
Top Washing Machines Experts
john h
