Question about Hawking 802.11g Wireless-G Range Extender
Setting up w/ Netgear router
Hi -- I called recently, I'm case # 60951. I have a model Hwdn1 extender. I was unable to set it up with my netgear router, even though the router settings are g/b, even after reseting it various times with the person on the phone and entering .235 and .240 ip addresses to test it. I'm ready to take the thing back next week but if someone can offer me some ideas or solutions I'm willing to try one more time. Thanks in advance for any help.
Pete
  • Anonymous Dec 13, 2008
    Same problem with identical kit. COULD NOT get the setup working. In the end I went and got a Netgear Wireless access point. Problems solved.
I've had the worst of luck with Hawking ANYTHING. I suggest taking it back. Sorry, but my experience with this product is such that if you get it working, it will break again within 24 hours.
Posted on Jul 07, 2008
How do you connect netgear extension to router
This article provides instructions on how to wirelessly connect to your NETGEAR Wi-Fi Extender using manual setup after the NETGEAR WiFi Extender has been successfully connected to the Access Point (AP) and obtained a valid IP address.
https://kb.netgear.com/25504/Unable-to-connect-my-NETGEAR-WiFi-Extender-using-manual-setup?cid=wmt_netgear_organic
Feb 23, 2017 | NetGear Computers & Internet
Mywifiext login
Do you have the range extender set up on the same live in the fuse box? If you have the one side on a breaker on the opposite side of the fuse box from the othrr side, it will not work well at all. That is why I encourage people not to waste their money on these things and get a decent wireless system so that you dont have problems.
Aug 19, 2014 | NetGear N300 Wireless Router
Not able to browse the sites using Netgear DGN2000 router...
May be good to disable all additional settings. e.g. firewall or Port forwarding. I am assuming that you are able to authenticate (connect with user id + password) as you mentioned youtube works fine. So in that case, there shouldnt be a basic issue but more of a port forwarding or nat. Also check your laptop for any setting changes or personal firewalls.
Try pinging local gateway, then DNS then any international website. Based on that you can focus on the problematic area.
Apr 07, 2014 | NetGear DGN2000-100NAS Router
Not able to connect the extender to my apple time capsule? no wps button. can i use this extender?
Hi, yes you will be able to use the Netgear range extender with the Apple Time Capsule, provided you configure the Time Capsule's wireless settings based from the wireless security you have setup on the Netgear router or extender. No need for WPS button. Just treat the time capsule just like another wireless laptop.
For instructions in setting up wireless settings of Time Capsule click on this link -->> http://www.apple.com/timecapsule/wireless.html
Hope this helps. Glad to be of service.
Nov 10, 2011 | NetGear WNR2000 Wireless Router
Why can't i connect to mywifiext.net
3 lights on every time last two days one light is on first last we dont on its the problam
Sep 30, 2011 | NetGear WN2000RPT Repeater
How to connect my Netgear Router to Xbox 360
First you need to do wireless setting on router,steps to do wireless setting on router
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. now click on ssid which be wireless-netgear..ch:11..security option select wpa/wsk ,under passphress type 9080706050
click on apply
now you need to do setting with Xbox360
link for doing setting on xbox
http://www.chasms.com/xbox/menu.htm
after click on above link please click on system/network setting
then follow instruction
Hope it can resolve issue
Thanks for using Fixya
Apr 13, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Apple ipod wont connect to netgear router
If you are unable to connect your Ipod, it means wireless setting on router is incorrect,you need to reconfigure wireless setting on router.Please follow steps to resolve your issue
Connect a computer with a cable to router.
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
5. SSID should be "wireless-netgear"(OR any new name)
6. Under security option select WPA>PSK
under passphress type "9080706050" then click on apply
Now reconnect your Ipod wireless
Hope it can resovle your issue
Mar 27, 2010 | Apple iPhone Smartphone
Can't Connect to Netgear Range Extender Kit
-- you can connect the Xe102 to he wall plug where ur router is placed
-- And then reset it from the reset hole on the back of the Xe102
-- and after that connect the WGX102 to the other wall plug where u wanna get wireless access ..
-- And then reset it from the reset hole on the back of the WGX102 as well
-- And once u do that it will not ask for a security key .
-- It will show netgear unsecured
-- try to connect with it and u will be connected
Feb 14, 2009 | NetGear WGX102 54 Mbps Wall-Plugged...
Connection error appears
You should call the isp, because it is a problem on thier end. They will help you fix the issue, and worse case scenario, they will come to your house and fix the issue.
Apr 25, 2008 | NetGear WGR614 Wireless Router
Open Questions:
Hawking 802.11g Wireless-G Range Extender Logo
306 people viewed this question
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
