Question about Acer Aspire™ T180 PC Desktop
YOU TUBE NOT WORKING CORRECTLY
MY YOU TUBE IS NOT WORKING CORRECTLY. VIDEO DOES NOT FLOW, FREEZES AND THEN "TIME-OUT" SIGNAL GOES ROUBND AND ROUND
That problems are also came to me.
At first you will clicked the Active contorlX( At the time, internet connected) and then install the Adobe flash player in ur computer.
atlast you will see the videos
Posted on Jul 15, 2008
2000 nissan sentra 2.0 error codes p0101& p0102
P0102 - Mass Air Flow Sensor Circuit Malfunction
The mass air flownissan-maxima-maf-sensor.jpg or MAF sensor is placed in the intake air duct between the air filter and the engine intake manifold. The MAF sensor measures the amount of intake air flow. The MAF sensor converts the air flow measurement into a voltage or frequency signal, with the voltage or frequency changing proportionally to the amount of air flow. The air flow sensor signal is monitored by the engine computer (ECM). The engine computer (ECM) uses the mass air flow signal to know the engine load and to calculate the proper amount of fuel injected. If the signal from the mass air flow sensor is out of expected range, the ECM detects a fault and sets the code P0100. For example, the mass air flow sensor signal could be higher than expected when the engine is not running or lower than expected with the engine running. A car with the code P0100 may have some driveability issues, such as stalling, lack of power, surging, hesitation, etc. In some cars, the code P0100 can cause the fail-safe mode where the engine speed would be limited to 2,500 - 3,000 rpm.
If there are other trouble codes present, they might need to be looked at first. Checking the freeze frame may help, as it may contain some important information. The freeze frame is a snapshot of the engine parameters at the moment when the fault was detected. The freeze-frame may show whether the vehicle was running or stopped, whether the air-fuel ratio was lean or rich, was the engine was cold or warmed up at the time of the malfunction. Read more about the freeze frame.
Read more about mass air flow sensor.
What could cause the code P0100:
- faulty or contaminated mass air flow sensor
- open or short in the mass air flow sensor electrical circuit
- open or short in the sensor power or ground circuit
- other electrical problem with the MAF sensor wiring, (corroded wires, bent terminals, bad ground connection, burned fuse, etc.
- vacuum leaks
- restricted air flow at or before the air filter
- wrong air flow sensor installed
- problem with ECM
P0102 - Mass Air Flow Sensor Circuit Low
The mass air flow or MAF sensor measures the amount of air entering the engine. The engine computer (ECM) uses the mass air flow signal to calculate the amount of fuel injected (read more how the MAF sensor works below). The code P0102 is set when the signal from the mass air flow sensor is lower than expected. Often a car may exhibit some driveability symptoms, such as lack of power, surging, hesitation on acceleration, hard starting, pinging (detonation), or rough idle when started cold. Often the codes P0171 or P0174 could also be stored along with the code P0102, as the incorrect air flow signal can cause the engine to run lean. The codes P0171 and P0174 indicate a lean condition. Checking the freeze frame might help in the diagnostic process. The freeze frame is stored in the ECM along with the trouble code. The freeze frame contains some recorded parameters (e.g. vehicle speed, engine temperature, fuel trim) at the moment when the fault was detected. The freeze frame can also be accessed with a scan tool.
What could cause the code P0102
- faulty or contaminated mass airflow sensor
- debris blocking the air flow at the mass air flow sensor
- unmetered air leaking past the MAF sensor (vacuum leaks)
- PCV system vacuum leaks
- restricted or collapsed intake air duct
- dirty or restricted air filter
- restricted air screen before the air filter
- improper application of aftermarket components (e.g. cold intake, modified air filter, etc.)
- electrical problem with the MAF sensor wiring, connector, power supply or ground.
- problem with ECM
- in some cases other issues with the fuel injection system like a clogged catalytic converter or a faulty manifold absolute pressure sensor (MAP) can also cause the code P0102.
Solution for MAF repair
Oct 20, 2012 | 2006 Kia Sorento
Water supply to the ice maker is freezing up,how can it be fixed?
Hi
Over time the inlet valve becomes partially plugged, reducing the outlet pressure and reducing the water flow rate into the icemaker. If the flow rate is too low then the water will gradually freeze in the tube until it becomes blocked entirely. Many times low water pressure will cause this. You can perform a taste. Get a piece of tubing and attach it to the inlet valve. Run this piece to a container and see if you get any water while the power is off to the valve. You might have a valve that is not shutting completely off. Hard water might cause this. Killing the power to the valve will make the valve inoperable. Actually the purpose of killing the power is to see if the valve is allowing water to bypass even when there is no signal from the switch to do so.Bad inlet valve could be the possibility. So it needs to be ordered and replaced because the valve isn't sealing off properly and it's causing the water to trickle through or drip through the fill tube sometimes, then it freezes before it reaches the icemaker and over time it will clog up the fill tube completely.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 04, 2011 | U-Line CO2075F-B Echelon Refrigerator Ice...
I have a Whirlpool Gold top-mount fridge (GR2SH/GR2SHM). It's about 6 years old. About a year ago the freezer started to have ice build up and water would over flow into the fridge. I defrost the...
The defrost cycle is not working. After a predetermined number of hours of compressor running time, a timer actuates the defrost cycle, which stops the compressor and turns on a heating element to melt the ice. Either the timer or heating element is not working. Also, make sure the melted ice water is actually draining and not re-freezing.
Aug 31, 2017 | Whirlpool Microwave Ovens
Model KTRS22MJB water from freezer flows to refrigerater, and settles at bottom under the produce drawers. Have had some one come out 'repair' several times before. They used an auger type tool? I should...
HI, I have seen this a lot in my 13 years of maintenance work, the problem is the drian line freezes up and when the frig goes into defrost cycle the water has no place to go so it leakes into frig. He is using the auger to clean ice out of drain line. After you clean out we would use a heavy guage copper wire and wrap around heating coil and put other end down into drain tube so when defrost cycle kicks on it will heat wire and drain tube will not freeze up,this would solve the problem and would never get a nother work order agian. Hope this helps.
Mar 05, 2011 | KitchenAid Refrigerators
Tiolet not flushing right. Water not coming down the side of the bowl when flushing and 90 percent of the water is gone from the bowl.
1- Check ports out under rim all round bowl.
2-Check tank fill level for required amount to with in 5/8" to top of over flow tube.
3-Make sure 1/4" fill tube is connected to over flow tube. From fill valve to overflow tube.
Below is a few details to go by I hope will be helpful for you to take care of this problem.
Under the rim of the bowl check the ports and make sure they are not stopped up. You can open them up with nail or pin to clean out ports.
Next check tank level and make sure the fill valve has a line run from it to top of the overflow tube. This line allows water to goe to bowl and tank to fill required amount needed.
Water in tank should be within 5/8" to top of over flow tube.
Jun 22, 2010 | Pegasus Technologies Two-Piece Round...
Water Freeze to Ice maker
Usually when this occurs it is due to a leaking inlet valve. Replace that and you'll be in good shape.
Oct 27, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker isn't filling with water. Water is on and ice maker is on. It's been humid.
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 16, 2008 | Kenmore 53642 / 53644 Side by Side...
Water freezes before getting to ice tray
sounds as if your water inlet valve is not closing fast enough allowing a small amoutn of water to accummulate in fill tube freezing and eventually freezing solid, would try replacing water inlet valve, or even the water filter if this model is so equipped
Feb 18, 2008 | Refrigerators
Acer Aspire™ T180 PC Desktop Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
