Question about Kenmore Dryers
Dryer My whirlpool gas dryer will heat up but clothes still take up to 1.5 hrs.to dry.apparently after it gets hot ,will will not reignite.
Today my whirlpool dryer started making a loud noise. it is drying the clothes but the noise is loud.
Posted on Jul 06, 2008
The flame comes on for 9 sec, then goes out for 1 min. and 15 sec. it takes about 2 hrs. to dry a tub of clothes. Is the thermo switch bad?
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils.
Nov 24, 2010 | Whirlpool WGD5900S Gas Dryer
Wed5300VWO dryer only dries clothes occasionally. Some times takes 1 1/2 hrs for small load. waist bands on pants damp etc, All thermostats have been replaced by repairman
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 11, 2010 | Whirlpool Dryers
Dryer is not getting hot, not drying clothes
heatman101
Jun 07, 2010 | Whirlpool LER4634J Electric Dryer
My dryer heats up but clothes take 2 hrs to dry can you help me? I have a whirlpool supreme
Is your dryer electric or gas? Is it getting hot? Please check to see if your lint vent and hose is not clogged with lint. It has to be blowing good. Any restriction will cause the problem you are having. Lint will build up in the hose/venting and will become a fire hazard also. If your vent hose is blowing good then your drum isn't turning. A new drum belt is then required. If your drum is turning and it isn't getting hot you need a new element or a igniter switch depending if it's gas or electric. Hope I helped.
Oct 16, 2009 | Dryers
Dryer isn't getting as hot as it should, clothes take twice as long to dry
clean out your wall vent,dryer hose and lint trap that should do it,what happens if you have a clogged vent the dryer keeps the wet hot air in loner and it take twice as long to dry-mike
Apr 20, 2009 | Dryers
Whirlpool Dryer LGQ9508PW0 flame comes on and shuts off after 30 seconds.
this might actually be normal, whats the complaint??? to long to dry clothes maybe 2-3 cycles??? would be a common complaint. in which id check to make sure vent is not clogged anywhere, especially where exiting the home if he venting is ok id replace the coils atop the gas valve, possible and common for that matter that after running for 20-30 min they do not reopen and dont allow flem to reignite... part number 279834 retails for about $20 easy enough repair.... reason for flame to go on and turn off after only 30 secs is that in an empty dryer 30 secs of heat may be enough to satisfy the thermostat, that's alot of heat for an empty dryer, it would remain on for longer with a load of wet clothes absorbing the heat
Nov 05, 2008 | Whirlpool LGQ9858P Gas Dryer
Whirlpool Gas dryer ignites when I first turn it on and gets hot but won't stay hot or ignite again.
replace the 2 coils on gas valve after warm up they fail to open valve to reignite burner
Nov 03, 2008 | Whirlpool LGQ8611L Gas Dryer
Initial gas burn does not reignite
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE;
Jul 26, 2008 | Whirlpool LGR7646E Dryer
Maytag Neptune MDG9700AWW gas dryer. Problems is the dryer runs for 3 hrs when drying clothes
be sure vent is clear all the way to outside try a load with vent disconnected ..also if gas dryer may be a problem with burner reigniting after heat up if so try replaceing both coils on burner valve
Jun 05, 2008 | Dryers
Dryers Logo
300 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
