Question about Coleman Heating & Cooling
Every year i get my central air unit serviced and they add R134a refridgerant to it. i was wondering how hard it is to do this, i change all my filters in my furnace and air flow is good, i just can't see spending $60 an hour for something i can prolly do myself.
    Champion:
  • 254 Answers
Ok first off you will need to know the expansion rates of refrigerants vs. temperature rise and gain. Next you need to know some algebra to equvilate what said pressure should be by temperature and type of refrigerant. Next you will have to find a place to take the EPA exam, then if you pass with an 75% or higher that step is complete. The next step would be to study for the B&A Exam this is a 6 hour exam that you must pass with a 80% or higher where I live. To take this exam you will need to spend $2500 on course work and another $4000 to $5000 on books. Then if you pass that exam the next step will be to buy a truck and tools this may range anywhere from $50,000 up to and sometimes above $150,000. Oh and I forgot that you will also need to get bonding insurance mine costs around $10,000 a year. Oh yes you will need a building as well that should be around $2500 a month. So there you go for around $122,500 you could get started on adding your own refrigerant. Please dont take this the wrong way, I get gripes all the time about my billing rate and it is $132.50 an hour but we have a lot to lose with our investments, and future investments.
Hope this helps Ya.
Posted on Jul 06, 2008
    Problem Solver:
  • 18 Answers
I remember Carrier came out with a 134a unit years ago but didn't sell very well here in TX. and I have never ran across one if this is a central air unit. If room a/c then there area alot of them. Get the leak fixed and you shouldn't have to add any. Anyone can buy 134a but then you would have to learn the pressures and buy a set of gauges, not a widow maker,( those cheap 1 hose and gauge setup that screws on the can)
The copper coil had a hole in it and all the r134a leaked out. I fixed the hole but cant find a spot to add new r134a? My car is easy to add it too, I thought it would be similar? Its a LG window unit....
Hello, in order To charge freon into tne system you need to add piercing valves to the low and high sides of the system. Here is a link to pierving valves http://www.apwagner.com/index.php?main_page=index&cPath=5_227
Jul 28, 2011 | LG Goldstar WG6005R Wall/Window Air...
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
What kind of refridgerant do you use for the air conditioner
in 93 you could have R12 or R134a ... R12 is now illegal to use for most cars .. so you would have to have your system retrofitted so it can use R134a ... you can see what kind you have by looking under the hood .. there should be a plaque that tells what kind and how much the system holds .. the R134a systems have a special larger filler port and that is easily recognized by anyone familiar with auto air conditioning .. so just a look will tell them ... R134a is known for slow leaks .. its a small molicule so leaks easily .. the compressor will stop when the pressure gets down too low ..thats to prevent damage .. for now anyone can purchase r134a and many people add it themselves but the law specifies that only certified people can do work on air conditioners .. R12 and R134a are not compatable so you cant mix them .. no matter what the only refridgerrant you can use is R134a ..
Jun 30, 2010 | 1993 Dodge Spirit
Central A/C takes a long time to cool house
The system should be either R-22 or R-410A
You need to go outside and feel the suction line (the big line) with the unit running, after the house is cooled down, it should be cold and sweating,if the humidity is not to low, if it is your unit is probably ok. High Effeciency units
usually have a higher suction pressure and temperature and can run longer, if it's sized right. After the house is pulled down to temperature and starts cycling, it should come on and go off about 3 times per hour. The longer the unit runs the more dehumidification it should do.
Aug 22, 2009 | Heating & Cooling
Wont blow cold air
First check and clean the filters, and the evaporator coil. (thats the "inside" coil that has the indoor air sucked through it, cooling it and then pushing it out the vents.
If the filter is clogged or the coils are dirty, it will not cool properly and potentially freeze up.
Also check the condensor (outdoor) coil, if it is dirty/clogged, it will run hot and not cool properly.
If all coils and filters are clean, and the fan motors are running and in good condition and it is still not cooling then you are likely low on refridgerant. (handling/purchasing refridgerant other than R134A requres a CFC certification by law)
Aug 20, 2009 | Heating & Cooling
Air conditioner is blowing hot air out what should i add
On a 92 you might still have the old refrigant that you cannot mix with R134A. You will need to adapt the system the new R134A (gaskets etc....). Does the compressor come on?
Aug 17, 2009 | 1992 Saturn SL2
The unit only blows warm air. it just stopped kicking on the condenser/compressor to make that radiator cold and blow cold air. any help?
The compressor is not starting either because:
1. The compressor has gone bad
2. The system is low or out of refridgerant. There may be a slow leak, when there is no refridgerant in the system the compressor will not start.
Fix:
Re-charge the system with appropriate refridgerant, if the system has a charge already or holds a charge when you charge it then the compressor should start.
If not the compressor could be bad, sometimes you can get a hard start kit instead of replacing compressor. If the system does not hold a charge then you have to find and repair the leak before anything else...
Good luck. Please give good rating, it meens a lot to me....Feel free to contact me again...
Aug 01, 2009 | Dometic Rooftop RV Air Conditioner
How do I charge A/C on my 97 dodge dakota
Hey Steffney..my name is Keith...to charge ya A/C on ya Dodge Dakota..you need to determine how low your R134a is...after that..you go to the autoparts store and buy the size can of R134A that you will need..some of the cans of R134A will have a servicing connector with it..some wont...so...when ya get that figured out...you start your truck and turn the A/C on maximum cool...and ya blower to high blow...then ya find ya low pressure side servicing port(its usually located on the right side under the hood..and it looks like an oversized tire inflation valve..but made out of aluminum) and you connect the can of R134A to it and follow the direction on the can of R134A....i hope this will help ya.
Jun 25, 2009 | 1997 Dodge Dakota
PAC L90 LT thermostat not working, unit icing over
No that would be either a dirty filter/coil ir low refridgerant if it's freezing in cooling mode.
Clean/replace the filter, clean the coil and if it keeps doing it, have a technician who is EPA certified for servicing systems with refridgerant to look at it/add refridgerant.
Mar 24, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
113 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
