Question about Candy Washing Machines
Stops mid way
My candy cbl 160 starts to fill up with water then stops for a while then starts again then stops dead. please help me thanks in advance
sid
I found the information on washer help
Posted on Jul 07, 2008
Machine stopped working during use.
Hello! There is a trouble shooting guide for major appliances that frequently suggest parts and video links on youtube that diagnose your problem & instruct you how to repair your appliance. The site is called Repairclinic.com. Make sure you have the model number before you begin since the instructions are model specific. Good luck.
Jun 21, 2015 | Candy CNW136 Front Load Washer/Dryer
When I turn on machine with a selected cycle, it starts to fill with water, and then stops dead, I think the drum is not turning, as usually it fills a bit with water, turns around, fills a bit more with...
hi there, it sounds as if your drive belt is loose or broken. when you put you ear to the machine can you hear the motor running, if the motor runs but nothing else happens its a sure sign that the belt is gone. whilst you might look silly doing this, it may prevent you opening the machine up to replace the belt if you not have to.
thanks iain
May 03, 2011 | Candy AQUA1000T Front Load
Fault 11 - inlet or outlet blockage
THIS TYPE OF M/C PERMIT WATER TO FILL IN LONG TIME IF THE PRESSUR IS LOW
I THINK AFTER ABOUT 3 MINUIT YOU CAN OPEN THE DOOR AND CHECK OF LEVEL OF WATER TO ASSURE IS LEVEL OF WATER IS SUFFISUNT OR NOT
Jun 14, 2009 | Miele Incognito G658 SCVi Built-in...
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer stops mid cycle
theres contact points in the timer and down below wherer the wires go into the motor. check them and if you find them to be corroded you canm clean the with emery cloth then reassemble the unit.
Oct 15, 2008 | Roper RAX4233PQ Top Load Washer
CBL 160 not spinning
itcould be speed control module, If the motor was gone it would not wash.
Mar 30, 2008 | Candy CBL160 Front Load Washer
Washer keeps stopping mid cycle
Bad timer motor or mechanism...accordianman
Mar 21, 2008 | Dishwashers
Washer stops dead immediately prior to final rinse
this sounds like the conditioner solenoid, this is the cold water valve that works as the final rinse is suppose to work, just before the final spin, check valve connections for open circuit electrically, work safe unplug from power supply first, if i have helped please rate me
Oct 02, 2007 | Candy AQUA1000T Front Load
Washing Machines Logo
111 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
