Question about Refrigerators
Igloo fr464. after mooving found does not work. possable causes. when plugged in do not hear anything trying to work. inspected for some sort of reset switch,unable to find.
THE ONLY FIX IS A NEW COMPRESSOR. DUE TO NOT MOVING IN UPRIGHT POSITION THE COMPRESSOR WAS DAMAGED. DURING THE 4TH I FIXED IT BY SHOOTING WITH 12 GUAGE SHOT GUN.
Posted on Jul 07, 2008
Part 2 when it tries to start i hear a click coming from the overload-start capacitor side of compressor. fan is working.
check the capacitor overload protector and starting relay if they are all good, if one of them is found not functioning replace it. with new accessory installed , plug in the unit. if still you hear a click and compressor don't start , replace it . before you start anything on the unit be sure you know what you're doing. if in doubt call the experts.thanks,
Mar 02, 2016 | Magic Chef Refrigerator. 10.0 cu. ft....
Why isn't it cooling? GE Monogram Beverage Cooler ZDBC240NBS
Sara you question does not tell us a MAKE , or model perhaps you need to search the manufacturer's website for support .
Feb 15, 2016 | Refrigerators
Igloo fr1082
Sounds like an airflow problem. No air going into ref section. Usually a defrost problem and the coil is ice up in freezer section preventing airflow.
Aug 13, 2014 | Refrigerators
Igloo FR1082 not getting cold
Sounds like lost gas in transit from supplier, or compressor running but not pumping. Is it under warranty?
Apr 10, 2014 | Igloo FR1082 White 10 Cu. Ft. Refrigerator...
I have an Igloo Ice 102 portable ice maker. The water is filled to the max level and the ice maker starts up then the Add Water lite goes on and it shuts off. Any suggestions?
I had the same problem with my Igloo ICE102, and this is what fixed it.
1) Press and hold the power button for at least ten seconds. It will flash very, very slowly.
2) Unplug it for 30 minutes and drain it.
3) Fill it back up, plug back in and turn it on. Immediately select the smallest cube size.
This is what the real manufacturer (Curtis) told me to do.
Their number is 800-968-9853.
Mar 02, 2013 | Refrigerators
Timer motor plug burned out
Any burn marks near the timer mean that the timer is now useless. They just can't take much abuse. Track down the cause before replacing anything. I suspect the defrost heater has cracked and shorted out causing the overload to the timer. Do a visual inspection of the heater first, then if it passes a visual inspection test it with a multimeter for Ohmage/resistance. Replace if it fails either test.
Mar 13, 2010 | Refrigerators
Icemaker doesn't work
Icemaker seems to be working now.
I think that moving lever and switching on/of helped. I see and hear that it is producing ice now.
Jan 10, 2010 | GE PSS26SGRSS Stainless Steel Side by Side...
Can't find replacement latching mechanism for Igloo cooler.
try Academy Sports they have a large selection of cooler parts
Sep 19, 2009 | Refrigerators
Frigidaire side-by-side stopped working
I would chech the components on the compressor. Take the cover off the compressor power terminals and inspect the relay for damage.The power outage is not a concern but the power surge could definately be the cause. hope this helps.
Jul 28, 2009 | Samsung RS2578BB Side by Side Refrigerator
Bulbs and bottom pcb blew, replaced but still not working
the start and run capacitors of the compressor can go short circuit and cause a big spike that can blow the bulbs, trip fuse etc. Inspect the capacitors for splits etc, you may well find that the start cap has blown and so there will not be enough current to get the compressor running.
Mar 18, 2008 | Zanussi ZX99 / 5 Bottom Freezer...
Refrigerators Logo
188 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
