Question about Haier Dryers
My dryer does not work there is no light when i plugg in or press power it was working just fine last sunday... what should i do????
  • 481 Answers
  • turn your breaker off then back on.
  • then check your door switch.
Posted on Jul 06, 2008
Kenmore dryer 79690272900
This is too broad a question. Does the dryer light go out when you press the button? It should, but the switch could still be bad. Is the motor receiving power? If yes, replace the motor. Is the belt in place so that the belt switch is working? Test the belt-switch with meter. Lastly, is the main control (logic) board still functioning? Consider this last.
Nov 27, 2013 | Dryers
Power going to door switch-light goes off and on with switch, press start switch-switch makes contact but dryer does not come on. So when on switch is pressed unit does not power on.
unplugg dryer,take the 2 wires off of door switch connect them together with electrical tape,plugg dryer back in hit start switch dryer should come on ,that tells you that the switch is bad,this can also done with a tester
Jan 23, 2011 | Dryers
Last night I dried multiple loads of laundry . . . the dryer worked fine. This morning when I pressed the button to turn it on nothing happened. The control panel is completely blank, as if the dryer is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Aug 24, 2010 | Kenmore Elite HE4 Electric Dryer
Just bought new wireless router Sunday and it's been working fine, stopped working this afternoon...please help
Keep the reset button(on dotted side) pressed for three full minutes.
While pressing, notice the lights on router flashing.
Now re-configure with the setup assistant disc.
Its sure to work now!
Jan 22, 2010 | Belkin F5D8236-4 Router
Dryers stopped working during cycle
My dryer stopped working during a cycle last night and won't start again. The light is no longer coming on either. The first thing I checked was the circuit breaker which was fine. Can anyone tell me other possibilities? What is the anser
Jul 17, 2009 | Magic Chef CYE4000AWW Electric Dryer
Message that battery needs replacing last week but it was still going
Remove the battery and ac adaptor. also remove any peripherals.
Make sure that ac adaptor is working ok
Then press power button and hold that for 20 seconds to statically discharge the notebook. Then plugge that into the mains (without battery) and try to turn on. IF Notebook will not boot. Call service as mainbord needs to be replaced.
May 27, 2009 | HP Pavilion dv9000z Notebook
Does not start when cold
There is a diagnostic worksheet behind the aluminum panel on the back. In it it talks about the ambient room temperature must be above 50 degrees.
Dec 15, 2008 | Maytag Neptune MDG5500AW Gas Dryer
My Kenmore dryer 70 series will ot heat up
the thermal switch is located on the back of your dryer. YOu will need to remove will need a 1/4 screw driver...then look towards the boottom of the dryer...the thermal fuse...its a white looking piece with 2 terminals on is really easy to replace it.but you can also check continuity. and if you do not have a tester.
1) unplugg the gas dryer
2) connect the 2 terminal together.
3) DO NOT hold it when you plugg it up..
4) plugg it up and check too see if your igniter comes on...and wait for the flame.
if you follow all these steps and your dryer still does not work. check your igniter.
Nov 25, 2008 | Kenmore 73952 Gas Dryer
Washer problems
How old is the washer? Some washers you can pop the top on if so check your power cord as it enters the washer. There may be a loose or burnt wire at the terminal block. Some washers won't start if the lid switch isn't making. Check that also.
Dec 11, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
121 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Haier Dryer Expert? Answer questions, earn points and help others
