Question about Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher
Water will not drain
Kenmore Dishwasher model #58715169401 will go through it's complete cycle but leaves water standing in the bottom in other words, it will not drain. Any suggestions? HELP!
Thank you
  • asnvic Apr 27, 2009
    Water in bottom when complete on Kenmore Quiteguard standard.
If the hose is connected to a food disposal system, which was recently installed, then you will have to puncture the hard plastic piece inside the hole where the hose was connected to the disposal.
Disconnect the hose and drain the hose as much as you can.
MAKE SURE YOU UNPLUG THE DISPOSAL and the DISHWASHER.
The piece is inside the hole and you will have to use a ice pick or a screwdriver. It took me some time to do because of the hard plastic and the ackward positioning of the disposal. The piece is the size of a quarter and it is perforated for the purpose of puncturing.
Once punctured through, take a pair of pliers to pull the piece from the inside of the disposal where you place the food to be grinded. Throw the piece away and connect the hose. Plug back the disposal and dishwasher and you should be ready to go.
Posted on May 07, 2009
  • 686 Answers
Check for dirty filter it's inside under drying element
Posted on Feb 20, 2009
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Dishwasher won't drain completely. Several inches of standing water left after last cycle
Sounds like the wash/drain selector valve might be stuck. my Kenmore operating solenoid rusted and hung up. I cleaned and oiled it up. You can also have something that got into the valve and it won't close, or an obstruction in the drain hose or the drain pipe connector. Something is restricting the flow or the pump itself may have a bad impeller. Does it wash with vigor or has it lost a little oomph and sound different? Does it leave any debris on the dishes?
Jan 25, 2012 | Dishwashers
Wont drain
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 06, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
My Dishwasher works but still leaves some standing water.
Check the filter unit located at the bottom (inside) rear for clogging. Sometimes food will accumulate in the filter and not allow the unit to completely drain.
Jul 23, 2009 | Whirlpool 24 in. DP840D Free-standing...
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 | Dishwashers
Water standing in bottom of dishwasher,after wash cycle is finished? This is a Kenmore model 665.1565591
My problem too recently.
I blew compressed air back through the drain line and let it bubble up in the standing water in the dishwasher. Then I put it through another cycle and everything was fine. Something must have gotten clogged and the air blew it out.
Mar 19, 2009 | Kenmore Dishwashers
Water in the bottom of dishwasher
try running it empty there is usually a drain hole in the bottom check if anything is in it or try a dish washer wash solution I bet the drain or drain line is cloged let me know if this dont work. Hows your sink draining
Feb 15, 2009 | Kenmore 17459 Free-standing Dishwasher
Standing water in my kenmore dishwasher after complete cycle
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
z
Jan 04, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher Logo
189 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
