Have a Toshiba M45 that shuts down whenever it feels like it. After the last time it shut down it will not boot.
  • Bob Hart
    Bob Hart May 11, 2010
    Random shut downs usually have something to do with heat or power. Check and make sure your a/c port is not loose and getting power to you laptop & check the a/c power adapter it self.
    Check your CPU fan try compress air to blow out anything that obstruct the airway.
    Problem Solver:
  • 6 Answers
DONE
Posted on Jul 09, 2008
Shuts down immediatley after booting up
I can assume from your description and this "click" sound that you are facing an HDD problem. I would suggest downloading Hiren's BootCD from this link. Burn the content on a disk and boot up from it. Then start some of the HDD tests like HDD Regenerator and examine the results.I hope this helps!
Nov 20, 2011 | Acer Aspire One Netbook
Satellite M45-S351 locks up won't shut down. First thing, may lap top would not shut down so we had to use the power button, then after some time 2-3 the unit decided not to boot up. we copyed the hard...
I think it is a prob with the mother board.........no need t change RAM or hard drive........they dont cause this type of prob. Ur mother board is not accepting the shutdown command.
Try the following command in command prompt:
shutdown /s /f
May 23, 2010 | Toshiba Satellite M45-S351 Notebook
My toshiba M45 takes several times to turn on,
what is your operating system? if you're familiar of what you're using, then it might be a hardware issue, please be specific,
if you're using windows, try running your OS to safe mode by turning it on and pressing F8 after bios load, it might be your Operating System is corrupted...
Mar 18, 2010 | Toshiba Satellite M45-S269 Notebook
Power jack feels loose and the computer shuts off
good day, you may want to buy a new power cord or replace the power terminal. hope this helps, have a nice day
Feb 08, 2010 | Toshiba Satellite M45-S169 Notebook
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
Will not shut down
you can go to the control panel, find power options, and than set how you want buttons to react.
Jun 01, 2009 | Toshiba Satellite M45-S2653 Notebook
Shuts off Randomly
I'm sure about this one. Your Charger is faulty, buy a new one, it happened to mine as well, buying new charger solved it.
Mar 23, 2009 | Toshiba Satellite M45-S331 Notebook
Toshiba Satellite shuts-down by itself in about 1 minute
Could be hardware or software problems, IF its hardware issue the only problem makes this if the Cpu fan doesnot work, so the Cpu gets hot and then it shutdown in order not to be damaged. but mostly its software issue that remeber if you installed any program before this is happen, and try to stop shutdown by this command, if you did this and this stop shutting down your laptop this is absolutley software problems or programs conflict:
hit Start, then Run , then type this : shutdown -a
this will stop your shutdown if it works, try to uninstall the last programs causes this issue,if it doesnot let you use safe mode command.
Regards
Mar 01, 2009 | Toshiba Satellite M45-S265 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
