Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 60PP9502 60" TV has problem with Red convergence or red and blue fringes
This TV start giving me problem just couple days ago. All of a sudden it start showing Red and blue fringes and hence you can see the saeds of every object in the TV with blue and red. Can u please suggest how to fix it.
  • Philips Master
  • 8,617 Answers
You will need to replace both convergence ICs they are both STK392-120 and you will also need four 6.8 ohm 1 watt resistors. you can get the Convergence ICs and resistors at the following link and they provide free instalation instructions with pictures so you can do the repair yourself. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Jul 06, 2008
On the screen I see on the sides of every object a shadow, it,s green on the left side and red on the right side accompanied by some little horizontal red stripes. It started doing it all of a sudden a...
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Hitachi 65TWX20B 65" Rear Projection...
I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
If the following doesn't work the tubes could be at the end of life:
Adjusting convergence:
Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
To adjust the convergence of the picture tubes:
  1. Press the 'MENU/SELECT' button on the remote.
  2. Press CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
  5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
  6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
  7. Press the 'EXIT' button to exit the menu.
If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
To Adjust multipoint convergence:
  2. Use CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
  5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
  6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
  7. Press the 'EXIT' button to enter ADJUST mode.
  8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
  9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
  10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
  11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
  12. Press CURSOR RIGHT to save the multipoint settings.
  13. Press the 'EXIT' button to exit the menu.
Apr 03, 2010 | Philips 51PW9303 51" Rear Projection...
I have a Philips 46PP9302 and can't find the Quick Setup guide. I'm wondering if it is located on-line. We moved our tv and want to recalibrate it.
http://www.retrevo.com/support/Philips-46PP9302H-TVs-manual/id/278ci462/t/2/
The above link should take you to the location where you can view all the parts of your models manual. Select the area of interest and rad onlinje
Please rate my help++++Thanks for using FIXYA
Nov 24, 2009 | Philips 46PP9302 46" Rear Projection...
I have a Magnavox 51MP392H/17 Rear projection TV. about 2 months ago the color start to merge into each other and showing double. I would cut the TV off...wait a few minutes then turn it back on and the...
yes its repairable
its a convergence circuit failure there are a couple ics and most likely some resistors that will need replacing and possibly a pico fuse
est 300 to 340 you mention only red and green though do you not have blue in your picture
id bet the blue is non exsistant and will need a blue liquid kit changed to correct that problem also
you might want to conatact a local servicer and give a model and ask them what they woud do both for then you can make a decision if you want to do it or not
Oct 31, 2009 | Philips Magnavox 51MP392H Rear Projection...
The red lamp on my phillips is not lining up
Here is a link to the manual for this bad boy. http://www.fixya.com/support/p220239-philips_magnavox_51mp392h_rear/manual-28755/page-52. Page 52 has a listing that says "If the picture has red or blue fringes, you may need to adjust the convergence. See page *Q-7." Follow the instructions there.
Oct 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Colors shadowing eachother, adj convergence, but will not save.
Sounds like your convergence IC chips have failed. You can buy the parts from various suppliers or you can just get a complete repair kit from www.TvRepairKits.com
Mar 15, 2009 | Philips 46PP9302 46" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Convergence has to be set daily
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergence amp ic are going replace them before you have more problems
Dec 12, 2007 | Toshiba 43H70 43" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
